budk1953
Been thinking about adding oil pressure and voltmeter gauges (and maybe a clock) to the Midget using the speaker grille area. Since it will be impossible to find Jaeger gauges to match the existing I might change the other gauges (speedo, tach, fuel, and temperature) so they all match. If I do this I'll probably use aftermarket gauges since Smiths will cost a small fortune.
The fuel gauge is the one that concerns me - I remember reading the full and empty ohm readings but can't find the post.
Anyone have this info handy?
Is there any other things I should watch out for with the other gauges?
Thanks
Thanks
