kyreb1862
I smelled gas around the back of my 77 B this morning and when I looked I found gas leaking from the sending unit area. At first I thought the seal between the tank and the unit might be bad. Closer examination however revealed something a little more bizarre. The gas is actually leaking out through the white nylon sleve that the wire to the sending unit plugs into. Apparently the gas is actually coming out around the spade terminal in the bottom of the sleve. Really the sad part about this is the sending unit was only installed this spring. Apparently this says a lot about the quality of the parts we are now purchasing. Is there anything I could squirt into this sleve to seal it off?
Regards John
Regards John
