Gas tanks????
nomad
I really could use a new tank. The car I am working on has a tank that looks as if it was backed onto a big boulder at some time. So, I'm wondering if anyone is familiar with the gas tanks that are currently on the market that are made in Canada. Do they have internal baffles like originals? Filter on the pick up? Screw holes that are compatible with the old sender? In general worth buying or should I try to straighten my tank. I have to take it off anyway to rectify a sending unit problem.
Kurt
JPSmit
Not sure if it the same brand but I bought a Victoria British Tank back in the day - problems, all bolted in and god quality. I recall that it didn't have the attachment for the return that the 1500's had but mine was gone anyway. I think they are easier to replace than repair
Jim_Gruber
And they don't have a drain built into the bottom of the tank. Before Install I took mine to a radiator shop and had a bung welder/brazed in.
N
nomad
Looks as if this tank hasn't got a drain either so I guess it isn't original. Think I'll replace it.
Kurt
Rut
Kurt,
The Spectra tank’s are of decent quality and don’t have baffles or a drain plug. I’ve used them on a Bugeye and an MGB without issue, but be aware that the fill pipe on the Bugeye tank may be a little short especially if the rear of the car has had any bodywork. If you decide to use one be sure to inspect the continuous weld that runs around the the tank to join the two halves...it’s been reported that some leak. These tanks are also coated with Nitern and it’s tough to get paint to stick to.
Good luck, Rut
N
nomad
Thanks Rut. This is for a Mk3 Sprite and i sprung for a tank on flea bay. Canadian made and the seller claim's it has baffles and a drain plug. The tank I have on the car now appears to be leaking from the seam. That could have been caused by the trama it's gone through though.
Kurt
SaxMan
I put the VB tank into my '69 Sprite. The biggest issue I ran into was discovering damage from a rear end collision that bent some of the studs where the tank bolts on, turning a rather easy swap into a ball buster, but I was able to make a successful installation. It still beat having to deal with the tank straps like I have on my '53 Plymouth.
Pythias
Then new one I got from Moss had no drain plug and .... the metal around the fitting was sure thin. .... I was trying to get the gas gauge to function. The sending unit (again from moss) float leaked, filled with gas and sank. The tank got pulled and new one installed. Then the tank started leaking around the outlet fitting. And again. The act of putting it in thrice and out twice weakened it so much that gas weeped out around that fitting. Luckily someone makes a putty to seal gas leaks.
I miss the drain plug.
YMMV
My 2¢
N
nomad
Hi, Bill!
Good to hear from you even if its a tale of woe!
N
nomad
I may have to attack a sending unit problem as well but, as of now, I'll save that till I have the tank off. New one isn't here yet and I'm putting the suspention back to stock because our roads are so bad I can't stand a performance ride. Spring club car show is the 5th of May.
Kurt
B BE vs. Later Model Gas tanks Spridgets 2
T magnets and gas tanks, and other applications Austin Healey 3
K TR2/3/3A Gas tanks...two different types? Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
P After market gas tanks for bugeye Spridgets 4
BobbyD TR6 TR4 & TR6 Gas Tanks Triumph 6
justin_mercier Fuel Cell gas tanks Triumph 13
S 100-4 gas tanks Austin Healey 7
T TR2/3/3A TR3 gas tanks Triumph 9
T TR6 TR4a and TR6 gas tanks interchangeable? Triumph 10
S TR2/3/3A Tr3 gas tanks Triumph 7
steved033 Best gas tanks? Austin Healey 11
blacksummerrain Bumpers, radiators, and gas tanks Triumph 23
R New Gas Tanks from VB Triumph 10
H Replacement Gas Tanks? Jorge Cervera? Austin Healey 10
H Gas Tanks Austin Healey 2
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A TR3 gas filler cap Triumph 1
J TR2/3/3A TR3A gas tank repair Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
Rut MGB Running out of gas symptoms MG 21
T TR2/3/3A TR3A Gas Cap Triumph 15
D Gas Pedal Pad Jaguar 7
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
Michael Oritt Gas cap parts now in tank Austin Healey 17
Rhodyspit75 Bonnet gas struts Spridgets 0
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
ckeithjordan TR2/3/3A Gas Filler Cap Triumph 1
R TR2/3/3A Installing gas tank Triumph 6
FlyingCat Spitfire No Gas to Carburetor Triumph 15
S TR2/3/3A glass rattled on the gas gauge Triumph 3
FlyingCat Spitfire Gas tank Triumph 2
L General TR Ethanol free gas Triumph 34
T vented gas caps? Spridgets 8
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
R TR2/3/3A Pin Hole in gas tank Triumph 9
