dklawson said:
Richter, out of curiosity, how did you get the fuel tank out of your GT6? It has been years since I painted our GT6 and one task I remember having to give up on was getting the fuel tank "out". The methods listed in books did not work at all as there was interference with other items. I could not turn it or position it in any way to get ours out.
I'm not being facetious when I say I don't know if I could explain it. You ever been driving along and have a near miss with another car and you just KNEW that you were hit, but somehow managed to totally avoid contact? I think it's like that. :laugh:
In practice, I had the hose disconnected from the vent, and the line disconnected from the bottom, pulled the cables from the sender, and removed the fuel filler hose and cap. Then holding the wires on the rear side of the car, I want to say I was able to wiggle the tank down so that the rear lip was down at an angle, and had just enough room to slip the frontmost piece past the crossbar and come up and out. My memory may be a little hazy - I remember trying about 20-30 different times with no real signs of progress and then suddenly held the thing in my hands much to my surprise.
Now, as for mechanics secrets, I used a healthy amount of 'verbal lubricant' and when doing things like this, I keep a rubber mallet nearby. Not for hitting anything, heaven forbid. But when you get fed up it has a good heft, flies a good distance across the yard, and it's big enough to find when you're done. :laugh:
What's funnier is I've had to take it in and out 3 or 4 times, and it's ALWAYS a nightmare to get out. (Healthy disregard for the laws of physics helps!) but it always just drops back in like nothing.
