TR4/4A GAS TANK FELT
bammons
Does anyone have a picture they took of their gas tank with the felt installed they could post? I searched here but did not see one for the TR4A. I have the service manual but not sure if I am seeing it all. Thanks Bruce
Sarastro
If you mean the felt pad that goes under the tank, I strongly suggest dispensing with it. It's a water trap, which leads to rust.
A lot of the felt used in British cars of that era was a bad idea, but, at the time, no one expected them to be around fifty years later.
B
bammons
I have seen pictures on other TR's not 4A's that had it on the side(s). The Moss catalog shows what looks like 2 strips on the backside but none on the bottom. Is that correct? Any particular place to put them? Is there a preferred glue to use on felt? I have 3M black weatherseal adhesive.
B
bammons
Thanks Madflyer. Ok not really getting the answer to my main question which is where to place the felt. I assume it needs to go over the raised ribs for protection from rubbing but I have seen 2 pictures with it cut out and placed between the ribs. It looks better that way but I question if it is serving it's purpose like that. Bruce
B
bammons
Just pulled out a old VB catalog which says 4A's and TR6 tanks are the same. But I just noticed it shows a felt strip under the tank and maybe one on top of the tank. So now I am confused as what little I had seen showed it on the backside (2 strips). I don't think the felt under the tank is a good idea as Steve pointed out above. Bruce
poolboy
It's not...I had to repair the tank on my 74 because the bottom felt held moisture long enough to create pin holes of rust on the bottom of the tank.
I don't have any felts at all on the 73 just a few strips of "RattleTrap" sound insulation on the front and rear....nothing on the bottom.
Sarastro
I don't think there is any harm to put it on the side, if you are concerned about some kind of rubbing. I would just put it wherever it seems right and attach it with some kind of glue or, as MFlyer says, tape. No one is ever going to notice whether it's "right" or not.
When I tore down my 4A, there was no sign that it ever had any padding on the side surfaces of the tank.
B
bammons
Ok - Obviously did not get a definative answer (about par with many things on these cars) so I will wing it and probably just do some on the backside. I did install a firewall so I will have to look at that close on the front side to see if it rubs. Thanks for your replies. Bruce
TRHARDTOP
Bruce,
Not a TR4 gas tank but...I have attached some photos of my 1961 TR3A tank that I did a few years ago. Showing the felt strips and the felt on the bottom of the tank. hope that might help.
Colin
Popeye
Bronze
Unfortunately my tank is inaccessible and I can't share photos of it.
My spreadsheet shows I installed four pieces of 611792, and I'm pretty sure this matched the felt I found (which I believe to be original).
However - like you said, the answer may not be black/white. Paul Anderson's site has great photos: > TR4A Petrol Tank <
"There seem to be quite a few different thoughts on where to place the felt. Many books and parts books put it in different places. So we decided to cover all angles other than the top."
Madflyer
Felt for the most part is a bad idea when moisture is present I used peel off rubber pads. there is also a padding made from milk bottles that does not hold moisture. Fabric shops carry it for outdoor use under seat covers. It is easy to work with and I use it as padding on say door panels and as carpet padding. REMEMBER our car were built in the 50's,60's and 70's it is a new world of materials today.
B
bammons
I notice that the Paul Anderson site shows that the pieces are cut and fitted in between the ribs. It looks better that way but seems you are not covering the protruding part which would rub first. I have seen a couple of other pictures similar. And he placed felt on the frontside of the tank as well although I can't see that is what is shown in any "manual". I think I will basically do what Paul Anderson did and quit worrying about it. It is not a concours restoration anyways and there seems to no real concensus. Bruce
T TR4/4A Alternatives to TR4a felt strip on gas tank Triumph 12
TomMull GT6 Gas Tank Outlet Triumph 0
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
B Damaged threads in the gas tank Austin Healey 7
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
B TR4/4A Gas Tank color? Triumph 4
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
D What's inside the gas tank?? Spridgets 13
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
J TR2/3/3A TR3A gas tank repair Triumph 7
Michael Oritt Gas cap parts now in tank Austin Healey 17
R TR2/3/3A Installing gas tank Triumph 6
FlyingCat Spitfire Gas tank Triumph 2
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Gas tank does not fit! Triumph 4
C MGB Found this spring in my gas tank MG 8
B Stripped Thread in Gas Tank Austin Healey 26
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
S TR4/4A Worm in gas tank? Triumph 7
PatGalvin TR2/3/3A TR3A Gas Cap Info and uel tank venting Triumph 4
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
AngliaGT MGB Gas Tank Removal - '67 GT MG 2
69MGC MGC New Gas Tank for my C MG 3
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
K TR2/3/3A Gas tank pipe connector? Triumph 6
S TR2/3/3A gas tank hole body work Triumph 7
maxwedge5281 gas tank and grill installation Austin Healey 29
K TR2/3/3A Gas tank to pipe connector.... Triumph 1
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
C TR2/3/3A Gas tank cover in cockpit area Triumph 3
J TR2/3/3A Gas tank fitting and ferrule Triumph 2
S TR2/3/3A with sugar in the gas tank Triumph 13
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
B TR6 76 TR6 gas separation tank - orientation? Triumph 2
C TR2/3/3A TR2 Gas Tank Triumph 6
R_Lyle TR6 Drain the fuel tank - five year old gas? Triumph 4
