I accquired a cool tool somewhere along the way that clamps on a cable and seels around the jacket. Then you simply put the little straw from your favorite spray lube in a tiny hole and spray it right down the cable til it comes out the other side. Real nifty. Mine was made for Yamaha Golf cars but it's a neat tool to have if you can find one.
I've got one of those cable lube tools for my motorcycle -- works well. If it is a cable issue, you can get a few made a bike shop (assuming it's similar to the one on the Bugeye). Mine cost only a couple dollars. You can probably make a couple cables for the cost of fixing your existing one.
I'll bet if you look at the spot where cable goes through brass grommet on the throttle linkage you'll find burrs or cable broken or frayed. Cable from local bicycle shop fixes the problem real quick. Even the ends match up on throttle pedal side. Pull out the inside wire and rethread.
Either that of throttle return spring got disconnected.
