My gas pedal rod has a deep grove cut into the shaft from the spring washer deal at the end. I am thinking I should be able to fill that with some mig weld and grind that smooth. Plus there is a hole for the pin close by and what is a good way to plug the little hole from welding up—little wood piece? And will a weld weaken the rod or make it brittle or something or is brazing better, or what is a good way?
