Skip & Lynne
Has anyone ever had to run a ground wire from the fuel tank to make the fuel gauge work properly. Skip
Found this old post after I had some questions about fuel tank sender grounding. So, does anyone know if it is true that the early cars used no ground wire on the tank sender?
If there is an added fuel filter between the tank and the engine, does this require an added ground?
