TR6 fuel pump
sundown
Hi, I need some help in trouble shooting the mechanical fuel pump, I think this is my problem with the car stalling out when I am driving it starts to die out then come back strong,sometimes it stalls right out then sits for awhile and fires back up?Any help please Thanks
TomMull
Could be many things. Have you checked for fuel at the carbs and for spark in stalled condition?
Tom
sundown
sundown
That's good thought but usually I'll sit for a moment then it starts and runs fine and fly home in case it happens again.It will sit an idle with not stalling until I take it out and put some acceleration on it. Thanks
poolboy
How about the fuel filter...one that's ready for renewal can make an engine act like that.
sundown
sundown
I just put a new gas filter in ,the plug wires are new ,points,condenser,new rotor and distribution cap.The car runs really strong except for the stalling episodes. I see gas in the filter do you think I am getting enough pressure from the pump when I try to accelerate .I would be going along great then it start sputtering and sometimes recover and be back to normal. Thanks
poolboy
If there is enough pressure to keep some gas in the float chamber, it's adequate pressure.
I did have a pump that seemed to work sporadically making it hard to diagnose...Finally after changing all the ignition related components to no avail, I put on my spare AC fuel pump and that proved to be the cure...
Maybe that's the answer.
sundown
sundown
Thanks for the input I think I'll get a new pump to eliminate that as the possible problem ,unfortunately I do not have a back up. Thanks
sundown
sundown
I just went out to start the 6 ,fired up great, let it idle for a bit shut it down put my ear to the fuel pump and heard gurgling noises coming from it is that normal or what? I'm thinking no. I already put my order in to Moss for a new pump hope that does the trick. Thanks
sundown
sundown
It was actually very distinct. Thanks for all the help I'll post my findings after the new pump is installed.
Tybalt
Is the problem worse when the fuel tank is low and not as much of problem when the tank is full? How about going up hill being worse versus going downhill? If so, every time I have seen those situations in a TR250 or TR6, it was a fuel pump that was on the way out.
sundown
sundown
It does seem to be less when the tank is full. Thanks,the new pump should arrive this Friday, I'm 99% it's going to solve the problem.
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S BJ8 Fuel Pump Austin Healey 13
S BJ-8 SU Fuel Pump Replacement Austin Healey 5
steveg Fuel pump inertia cutoff switch Austin Healey 33
Csarneson Fuel pump options Austin Healey 10
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
Bayless How do you mount a Facet fuel pump? Spridgets 10
Got_All_4 TR6 Fuel pump rebuild, Part not included Triumph 4
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
S T-Series su fuel pump MG 0
M Fuel pump question Austin Healey 3
R Solid state SU Fuel Pump Austin Healey 2
PAUL161 T-Series Hardi Fuel Pump - Germany MG 4
Bob_Spidell Hardi Fuel Pump Austin Healey 39
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
S For Sale fuel pump Pos grd Austin Healey Classifieds 0
NutmegCT T-Series SU fuel pump fun MG 20
NutmegCT Type L SU fuel pump Austin Healey 8
Bob_Spidell BJ8 Fuel Pump Trivia Austin Healey 0
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
sundown TR6 new fuel pump Triumph 4
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
