metropolisman
all,
i just converted my 66 bj8 to negative earth and purchased a new su negative ground fuel pump. I checked the power coming in to the pump and I’m getting 12 v ,the ground wire is properly attached to the mount bracket bolt and when I turn the ignition on I only hear a click, the pump is not cycling like it should .could this be that the pump is not properly grounded or is it something else? I retained the su pump box and it is marked negative ground. Thanks in advance for any advice you can offer.
Hi Guest!
