Csarneson
My BN4 sat in a field for 40 years and is slowly coming along. The engine will hopefully run again later this summer but I need a Negative Ground fuel pump. Originality is not necessary and cost probably isn’t a decider either. I’m doing lots of modern upgrades so solid state doesn’t bother me. What I want most is reliability. A pump that bolts into the original location would be helpful too. I will most likely add a second small flow through pump in series like Lin did as well.
Fuel pump options:
Hardi solid state- $129
https://www.bpnorthwest.com/austin-...ual-polarity-bn1-bn4-mg-tf-mga-mgb-to-64.html
SU solid state - $157
https://www.ahspares.co.uk/austin-h...ts/fuel-boot/petrol-pumpelectronic-earth.aspx
SU points - $134
https://www.ahspares.co.uk/austin-h.../petrol-pump-dual-polarity.aspx?¤cy=usd
Rebuild my original? Is that even an option? It sat in a field for 40 years so i’m skeptical. If so can I do it myself or should it be sent off to someone?
What option would you choose?
Fuel pump options:
SU points - $134
