Fuel Pump & Gas Line fittings
rlich8
Hi all,
I have a problem. The inlet and outlet fittings on the fuel pump on my TR4A are leaking. I presume this is something I can get locally, or will I have to order from Moss? Can someone post a picture? Would like to drive my car over the nice weekend...but not with fuel leaking out, even just slightly!
Thank You!
TR3driver
Great Pumpkin - R.I.P
Last I checked, you couldn't even get the right fittings from any of the Big 3, let alone your FLAPS. The original compression sleeves were a different shape than modern sleeves, and typically the fitting nuts won't go in far enough to compress them properly.
Here is one solution:
https://docs.google.com/viewer?a=v&p...Uz&hl=en_US
rlich8
rlich8
I now understand. I will use that solution. Seems logical and reasonable. Do you by chance know what size Ferrule? I think it's 1/4. thank you for your help!
TR3driver
On a TR3, the inlet is 5/16" and the outlet is 1/4". I assume the 4A would be the same?
rlich8
rlich8
Great! Thank you sir.
rlich8
rlich8
All fixed. The trick is to do exactly what that article said. I picked up some ferrules and a new brass fitting for the input line. Took the fuel pump off the car. Spilled a [censored] ton of gas (DOH!). Cleaned the fuel pump thoroughly and made it look nicely.
I first installed the inlet line, it tightened up nicely. Then, I installed the outlet line *loosely* and gently put everything back on the car. Tightened up the fuel pump w/ a new gasket, to the engine block, and tightened the connector between the line and carbs. Tightened up the outlet line, and everything is now fresh!
No more leaks. Squeaky clean, and super dry!
Thank you!
longbridgehealey Fuel pump racing, no gas Austin Healey 26
J New SU Fuel Pump - Gas leaking out of carb vents Austin Healey 24
Walk New Fuel Pump & Rebuild Carb - No Gas in Between! MG 21
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
