Fuel pump and mysterious cannister
Bruce74B
I took Dolly Clementine to a real garage last week to get the alignment checked after rebuilding the front suspension this winter. It was right on..amazing for a 30 YO car. But while he had it on the lift, the mechanic noticed a canister in the fuel line hanging down and rubbing against the reat spring and helpfully tied it up with a wire strap. On Sunday, I backed out of the garage and she stalled...after a little exploring, I discovered that when he tied it up, he pinched a rubber hose between the fuel line and the cannister. This cannister is about 5 inches long, maybe 2 inches in diameter and in hooked up between the fuel pump (I don't think it is an original pump) and the fuel line.
Does anyone know what the cannister is? A pressure restrictor? A filter, as it seems rather simple, in one end and out the other?
Does anyone have a good picture of what the fuel pump and related wiring and pumbing should look like?
I am half afraid to unhook it but I can't get enough fuel through it to keep the car running for more than a couple of blocks.
Bruce /ubbthreads/images/graemlins/cheers.gif
aeronca65t
Really sounds like an aftermarket fuel filter.
Some of the newer fuel filters (made for fuel-injected cars) are much larger than the traditional size filters used for carburetted cars....perhaps it's a filter intended for an injected car. It's probably fine (as long as it doesn't rub against anything).
Steve
Platinum
Another possibility is that this could be one of those "snake oil" add-ons designed to give better gas mileage/performance/emmissions/etcetera, fitted by a previous owner. Could be a fuel filter, but this sounds too bulky to be even an aftermarket item. Certainly doesn't seem to be anything that the factory may have fitted.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
.after a little I discovered that when he tied it up, he pinched a rubber hose between the fuel line and the cannister.
[/ QUOTE ]
Does this mean that you un-pinched the hose & still have problems? If so, the pinch must not have been causing the problem. The can is probably a filter which is a good thing to have, with old, possibly dirty tanks. If in doubt about the filter being clogged, replace it. If it filled up once, it is probably still needed, & may gradually fill up again.
B
Bruce74B
Let me clarify...I moved the wire tie holding the cannister up onto the outlet, but the hose is still kinked a little bit to cause a slight restriction, due to the angle it is at now. I am pretty sure it is a filter, but is solid metal body, the likes of which I have never seen. I put a new gas tank in last year, so I don't think I need it...so I guess I will remove it and see what happens. I do have a see-through filter in the conventional location.
Thanks for the input /ubbthreads/images/graemlins/thumbsup.gif
B
Bruce74B
Thanks, Dave....I think we have identified it as a filter...soon to be removed and discarded, so the fuel line will align properly and let the gas flow. /ubbthreads/images/graemlins/driving.gif
The knowledge of the people on this Forum never ceases to amaze me! /ubbthreads/images/graemlins/thumbsup.gif
mjamgb
Agreeing with the others that it is most likely an aftermarket fuel filter.
The position (before the fuel pump?) is not a good one. The pump is weak in suction and will not pull fuel through a decent filter very well, much less a clogged one. A much better position is just before the carbs (and a place you can get to it easier). I have found that the 99-cent see-through plastic units are plenty good and easy to check whenever the bonnet is lifted.
When you do remove the offending cylinder invert it over a glass container (input side down) and take a good look at what comes out. Lots of rust chunks may mean a good flushing of the tank (at least) is in order.
Another possibility is that a small pool of water collected in the large housing of the filter. When it was re-positioned the water happily flowed up to your carbs. Checking the carb bowls may be wise as well!
Mike!
B
Bruce74B
thanks for the help...I untwisted the pinched hose and the gas is flowing fine now. /ubbthreads/images/graemlins/driving.gif
Bruce Bowker
[ QUOTE ]
[/ QUOTE ]
I would still put in a small inline filter regardless if tank is new or not. These are quite small and can be well hidden or obvious. Won't be so big as to cause a kink problem. Available at any auto store.
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
