Dave Richards
dklawson said:Move your tests to the gauge itself and focus again on the green/black wire. You're not looking for a short of the green/black wire... that would produce a reading of Empty. You're looking for an 'open'. Look for a break in the green/black wire, run a new test wire between the tank and gauge if necessary.
Return to the gauge case ground itself also. I know you said it's secure, but make sure that both ends of the gauge's ground wire (gauge and chassis ends) are clean and making good contact. Add another ground just as a check.
I will follow up on the second paragraph. I already did run a lead from the sender to the gauge with the same result as having the grn/blk wire connected, the gauge goes full tilt.
I believe the ground at the gauge is good because the lamp works when it's connected and doesn't when it's not, but I will run a ground lead to see the results.
Thanks everyone for your input, because I'd be at a loss without it.
Hi Guest!
