I just took out my front bearings to check,clean& repack and on inspection decide to just replace them. I plan to order 2 oil seals,2 bearing hub-in,2 bearing hub-out. Should I get a couple new spacers while I'm at it? And what about the "shim" ? how do I know which ones to get?(.003, .005, .010, .015) or should I just re use the shims that where in there ? It's a 61 AH3000 car# HBT7l/13279. So that makes it a "BT7" .....I think???
Hi Guest!
Even a feeb like me has had success rebuilding most of the assemblies on my BT7 with the help of the factory manual. Well written ,concise, and easy to follow. --elrey
--elrey
