V
vagt6
Hello, all. It appears that my front tires are a bit worn on the outside edges which may indicate that my toe-in is off.
BTW, the suspension is tight, no wobbles, rattles and the front wheels have no play.
Questions for the experienced masses out there:
1) Is the Moss "alignment gauge" worth purchasing? Doe it do the job?
2) How many turns of the tie rod end locknuts in order to move the alignment? One flat; two flats???
Anything else I should know about this job?
Thanks, guys!!
Thanks, guys!!
Hi Guest!
