Front suspension and oil pan
bugedd
The car had a high front ride height, so today I took it apart. Attached are pics of the springs, which are the same length as stock, with a 1" thick rubber bushing that was at the top of the spring between it and the car. I don't recall this rubber bushing/spacer on my old car, and don't see it in any schematics. Did someone put that there to up the ride height? Is that supposed to be in there?
And the oil pan is something I've never seen before.....
JPSmit
looks like someone installed a toilet flange because they couldn't find the correct rubber isolator.
bugedd
bugedd
I looked at Moss' schematics, and I didn't see an isolator. Is there supposed to be one, or spring on metal, or??
smaceng
I looked at the Mini-Mania parts catalog for the Sprite, and it does not show a rubber isolator for either the top or bottom of the spring.
BTW: If you can find one of these catalogs, they are great....listing for original p/ns and great illustrations.
Jim_Gruber
Why don't you simply ask John. Looks to me that you have some special oil b
pan and there may be some trick involved with suspension.
bugedd
bugedd
That oil pan goes with the theme of the car. The rear end has a welded in panhard bar, nicely done. The front wheels have spacers shimming the front wheels out a 1/4". I'm assuming someone put the rubber spacers in to stiffen up the front end. Someone loved to rail that thing in its past life. It was nice to get under it today and look things over, the sheet metal is pretty clean under it.
BlueMax
Installing the rubber isolators would not stiffen car spring rates, Sprites/Midgets never used rubber isolators on spring seats. I suspect their was some tire rub and needed to raise ride height to stop rubbing as well installing front wheel spacers. The oil pan appears to look like a Winners Circle 6qt but the drain plug is in a different place. It could be from Tom Coby's Speedwells shop?
JPSmit
Let me quickly add that I couldn't remember if there was an isolator or not - but, have been working on the front end of the Vauxhall - which does have one :smile:
nomad
Your suspicion's are the same as mine...looks like a method to raise the front to avoid tire rub.
Kurt.
bugedd
bugedd
K, thanks guys. I'll put her back together without them. I can't see why there would be tire rub on the car, its no different than my last car. Perhaps wheel offset or something like that
or it had different wheels at one time.
BlueMax
Track on a Bugeye for the front is 3' 9 3/4" rear is 3' 8 3/4'. Unless someone had used a wheel with not enough off set or the wheel is wider than 6" shims wouldn't be needed? I think I ran into that issue once before myself, I'm using a 1/2" spacer on the rear of my car so that front and rear are the same track with no tire and wheel extending beyond wings at the top.
nomad
When I was running 165/80's on stock rims I had tire rub when turning in and out of parking lot's with sharp entry ramp's. Can't seem to find them anymore so I'm now running 155/80's.
Kurt.
bugedd
bugedd
I got the Moss 340lb springs on it, seems to have good clearance but it much harsher, especially the input at the steering wheel. Kinda thinking of putting those rubber isolators in to see if I can reap the benefit of better handling but a bit of cush from the isolators.
BlueMax
Increasing ride height will only introduce more body roll. If you want a softer ride, change springs rates and work the body roll with different sway-bar thickness.
nomad
I really like the 340# springs but have only fitted them to square bodies. BE might be a little too light in the front.
Kurt.
Does the car have polyurethane or nylatron bushings?
bugedd
bugedd
They are poly on the anti sway bar, but the rest I believe are rubber. I'll climb under it tonight to check it out. The rear of the car has the lowering wedges in it as well as the S-shaped leafs, so the goal was the level the car out. The 340lb springs accomplished it, just a bit harsh. I don't know if perhaps the stock springs with a spacer kit for the spring pan might lower it enough?
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
Popeye TR4/4A TR4A front suspension quesions Triumph 19
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
C TR2/3/3A Question on assembly of front suspension Triumph 3
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
maxwedge5281 front suspension or braking improvement Austin Healey 25
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M Adjusting Front Suspension Austin Healey 11
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
bugedd Front suspension springs Spridgets 4
M front suspension rebuild parts list Spridgets 22
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
F TR2/3/3A front suspension Triumph 3
