Jim_Gruber
Threaded rod works well with a double nut. 3/8 as I recall as well. one of the few coarse threaded bolts on the entire car. A really deep socketand an impact wrench makes those puppies go on and off in a few minutes. Back off one bolt. inert threaded rod, tighten part way, remove 180 degrees out threaded rod goes in partway, now can remove other two bolts and finally vback threaded rod completely out. Reassembly is opposite of above or something like that. Once you get in there it will be obvious.
