Front shroud and fenders
Skip & Lynne
I am finishing up painting the outer body panels and assembling them on the car. I think I can bolt the fenders to the shroud and then spread the fenders just a little and slip them on the car in one piece. I don`t want to run the risk of scratching the fenders by leaning over them and bolting the fenders on. Yea I know what I sound like. thanks Skip
Keoke
My advise Skip, /ubbthreads/images/graemlins/nonod.gif /ubbthreads/images/graemlins/nonod.gif Don't try it,besides the shroud must be sealed to the scuttle and the front brace.---Keoke /ubbthreads/images/graemlins/frown.gif
Cutlass
I agree. The finest fit and finish jobs require block sanding and color painting after assembly of the fenders, doors, etc.
Johnny
[ QUOTE ]
[/ QUOTE ]
Most assemble the fenders onto the shroud loosely, then paint, allowing paint to go down into crevice. You can tighten later on. Of course you can paint the inside of the fenders off the car. When it comes time to install the fender beading don't forget to tape the sharp ends before sticking in the crevice formed from the fender to the shroud. Click on the attachment above for a photo of my car ready to be painted.
S
Skip & Lynne
Hi Johnny thats something like what I was going to do. I have the fenders and shroud already painted color sanded and buffed out. This is how I am able to get a really glossy finish right up to the beading. No one will ever see it but the shroud and fender flanges are a glossy as the outer parts.I was going to install the beading without the fenders on the shroud then bolt the fenders on loosely and slip the entire thing over the car. I took them off that way I don`t see why I can`t put them back in the same manner. Skip
John Loftus
Skip,
Your attachment is not working when I click on it.
As to your original question, I think you could install the shroud and fenders as one piece if you have enough helping hands at both sides, front and rear (seems like you would need at least 3 people to avoid scratching anything). The problem areas would be getting the fenders to go around the hinge shut face (considering you need to do both at the same time). You also need to look at the small shroud attachment panels that get riveted to the shroud and bolt onto the top of the inner fender. Getting to those with the fenders on may be difficult.
Cheers,
John
bluemg
Skip
What about the shroud being sealed to the scuttle and front braces, could you explain that further?????
S
Skip & Lynne
I was going to apply the sealer before I slipped the shroud and fenders on then push the shroud down onto the bead of sealer and fasten it down. I have 3 sets of extra hands but after hearing from others I guess I will bolt the fenders on after the shroud is on the car. Skip
Keoke
Hi John, /ubbthreads/images/graemlins/iagree.gifVery good points, also do not forget to mention the two rivets at each side which attach the shroud to the scuttle. If the front end was removed as Skip indicated then the car had been dismantled by others and improperly reassembled.---Keoke
Keoke
[ QUOTE ]
[/ QUOTE ] OH! and do not forget to put a line of"caulking" about 1" wide and about 1/2" deep all the way across the scuttle set about 1/2" back from the fire wall to form a heat seal between the shroud/scuttle and firewall.Do not put any presure on the shroud other than that required to line up the rivet holes inside the cockpit and the screw holes on the engine side of the shroud. Caulking that squeezes out should be forced back into the crevice with your finger. This is in addition to what ever sealer you have chose to use.-- /ubbthreads/images/graemlins/cheers.gif--Keoke
Johnny
Better have lot's of help. Make sure the motor is in also. Are you sure you can bolt the shroud in completely with the fenders on? Just asking, I really don't know. One area of concern is where the front shroud fits onto the two frame rails. Also make sure the doors are protected as the fenders might come in contact with them.
S
Skip & Lynne
You are probab;y right Keoke this car had the front end replaced several years ago following a fire that started from the intake drains dripping onto the hot exhaust. Skip
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Marvin Gruber Front shroud piece needed Austin Healey 16
Healey Nut Front shroud badge Austin Healey 66
BoyRacer front shroud templates for 3000 Austin Healey 4
B Fitting grille surround to front shroud - BJ7 - any advice? Austin Healey 21
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
E relief map of lower front shroud 61 bt7 tricarb Austin Healey 0
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
T Front Shroud Qustions Austin Healey 8
T 1955 BN1 front shroud Austin Healey 3
T Austin Healey front shroud FORUM Navigation Questions 1
H front shroud-pls clarrify holes for me thanks Austin Healey 9
O front shroud work in Northwest Austin Healey 5
H Wheight front shroud Austin Healey 3000+transport Austin Healey 18
richberman Pictures of BN4 front shroud/chassis joint Austin Healey 5
J Healey BJ8 Front Shroud Phase1 / Phase2 ? Austin Healey 7
Y Restoring a 58 100 six front shroud Austin Healey 1
T Front Shroud Adhesive Austin Healey 10
T 100 Front Shroud Attachment Austin Healey 0
J front shroud to fender welt Austin Healey 4
C Front apron to shroud clearance Austin Healey 21
B Front Shroud 1974 Spridgets 10
Bob Claffie Front shroud asm Austin Healey 5
timbn2 Front Shroud for 100 Austin Healey 2
AUSMHLY Rain channel screws, front shroud Austin Healey 1
AUSMHLY Front Shroud replacement Austin Healey 28
N BJ8 front Shroud Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
