Front Left Brake Line
jhorton3
How should the brake line route from the brass union to the left front? Should it go on top of, behind, in front of, or below the crossmember? Also what holds it in that area?
On my BE it goes behind the RF shock, in front of the upper cross-member, down and then across. There are a couple of little clips like the ones on the firewall that the line clips into down below as it goes across! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
just press in clips.
I think Drew has posted a picture of the engine bay of the '74 tub he had, showing the routing. You might PM him and ask. It's hard for me to get a decent picture of either the '72 or '74 I have here, as they are fully assembled. I don't have anything of the proper vintage opened up right now.
Jeff
Drews pix just miss what you need to see down in front I think, but you can see where the line goes to from the junction!
Just looked, but no pix. From the union it drops down and angles fwd parallel to the shock mount, inboard of the shock. It then drops below the rack, about even with the front edge of the rack, on the top side of the crossmember. It crosses over, <u>under</u> the steering column, comes back up, and follows the plane of the shock mount rearward, inboard of the shock. Once past the shock it turns and mates with the union to the hose.
I hope you can make some sense out of that. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Jeff
Thanks guys for the pics and suggestions. That line will probably be quite a challenge, and I'm not looking forward to bending that one. Those clips you mentioned are the same type that hold the fuel line on the frame edge in the transmission tunnel? I seem to remember some talk a while back about moving that front left line from the front of the crossmember to the back to reduce the risk of damage?
No no. The clips in question look like bobby pins but tough, Should be a couple on the rear for brake and fuel lines.
The same type of clips can be found just above the battery box, holding the brake/clutch lines to the firewall! Bending the tube is really not too difficult if you just bend a little bit at a time and shift the "apex" of the bend just a bit with each bend. Just be careful not to kink the line!! /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
M Wanted Bj8 left front wing Austin Healey Classifieds 3
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
GTP1960 TR2/3/3A New left front wing body panel from TRF? Triumph 11
L Oil under left front shock Austin Healey 7
AUSMHLY BJ8 left front directional problem Austin Healey 17
G Advice needed in removing front left fender. Triumph 2
A TR2/3/3A TR-3 LEFT front fender Triumph 6
Shinsen774 My Left Front Lever Shock is Leaking MG 11
Alfasudcrazy Knocking sounds coming from front left - Jaguar 2
MgKid1974 Need Front Left Fender Please! MG 10
K looking for a left front wire wheel hub MG 3
S MGB Left Front Fender needed for '75 MGB MG 0
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
