19_again
https://www.villagephotos.com/pubbrowse.asp?folder_id=1892816
I am trying to remove the front hub, Bentley book does not show this setup. The metal stub in the hub feels threaded, and the access hole in the hub is situated above solid metal, no pin or screw to loosen/remove. I knbow there's a hub removal tool 18G 363, but I can't make sense of what appears to be a grease retainer from a standard bolt on wheel. This is wire wheel hub. Help!
