My front engine plate curves outward at the foot mountings where the engine mounts go through. Is that normal? Engineered with a little curve? Or is my engine plate bent? The plate is flat for most the the mating surface with the block, but it's clear that where the lower curves are, toward the feet as indicated, the points of mating at each side, toward the lower part of the block, is potentially narrow, like 1/2 inch before the face departs from the block and leans toward the engine mounts. Thoughts? thx
