Front engine oil leak
I think I found the problem. Check out this video! it addresses the two little screws. I think I have the wrong ones.
https://www.youtube.com/watch?v=rad7cdJmT6k
I can believe they got it wrong in under a minute. The bolts he is using are NOT the right ones at all. While the bottoming out issue is correct, late 1098 and all 1275 blocks (the one he is demonstrating is a 1275), use countersunk socket head screws. The reason being that a hex head bolt will fowl the dual row chain sprocket. Try dry fitting your timing gears using hex help bolts if you doubt it. Hex bolts are used on early engines with the single row sprocket. He issuing a single row sprocket for some reason, so it's not an issue in this demonstration. I don't know what that front plate if from as the ears for the motor mounts are missing. Apparently, that's a Mini block, indicated by no flange at the rear of the crank. I thoought those still used a double row chain, but with the tensioner, I guess they went back to single row.
As a side note, the dial indictor should be placed in the center of the piston, not the edge, and since there is some dwell at the top of the stroke, you need to roll a few degrees before and after TDC to find true TDC. :grumpy:
It you have a double row chain, which you should, you can see how close the chain is to your front plate. There is no way it would clear the hex head bolts.
Yes, the allen screws I have turn out to be correct/original, however, the issue he discussed in the video is definitely my issue.
Turns out those two screws were slightly loose, either due to vibration or perhaps I didn't torque them up correctly prior to assembly.
I tested it with some thin 3 in 1 oil. I put the oil in the little area between the sump drain holes. In a minute or two it leaked through exactly as before. Then I wiped dry and tightened the two screws. Tested with the oil again and seems like that was it. Very minimal leak after sitting 10 min. I torqued them up some more and that seemed to stop it completely.
I wonder if I need to pull off the front plate now? Maybe I should just put on thread locker and tighten the screws as much as possible with the allen wrench. I may also add a little RTV in that space between the drain holes.
I think you'll be fine tightening them down, but I would clean the threads well and use some thread locker on them. If you could loosen the plate a little and get some sealant in there with a palette knife, that probably wouldn't hurt, but you may be OK anyway.
I don't want to stomp on your thread but I've be watching this as I too have a front end oil leak.
mine only leaks when the engine is shut off and it leaves about a quarter size drop.
could the bolts referred to be the source of this leak?
SD Bugeye: That's how mine acted. See the photos I posted. If the screws do not draw the plate up tight, the leak traces down the back of the front plate over that inch or so of plate located at 6 o'clock. It then collects at the the bottom of the plate which is flush with the bottom of the timing chain cover. Then it drips from there.
So mine does not drip while engine is running but immediately after same for you?
Yes, it only dripped after I turned it off.
What was happening was that after the engine shut off, the oil drained down and settled in the bottom of the timing cover. That little bit that didn't drain back through the drain holes had to sit against the area long enough to slowly seep through. When it was running I suspect the flow prevented it from sitting against the spot.
Well it looks like I'm set for a project now.
but at least now it sounds like you have found the source of the issue.
That and the mystery of my ability to only pull 3.5 gallons from my gas tank. After an aggressive romp with my buddy tying to chase me around some corners guessing the pickup tube is slammed sideways. I now have some things to fix.
Ha!
I fixed it!
well no not really bought a bar BQ mat at lowes .
Maybe this winter I'll pull it apart to nice out now.
I fixed that leak but now I get a drip or two from the timing cover/damper oil seal. Didn't have that before. At least it's pretty minuscule at this point. Sheesh.
Fred, it seems as if you are attempting to make your Sprite stop leaking oil. This is in direct conflict with the laws of nature, and nothing good can come of it!
"Only those who attempt the absurd can achieve the impossible"
-Albert Einstein
Oh yea thanks for that.
now I feel as if I have let her down saying wait till fall maybe winter.
so sad I know
i'll take here for a nice drive give a good wash and buy here a new pair of shoes
Ah I mean tire's
:encouragement:
