vping
Well I worked my butt off all week in preparation for the front end swap on my '74 B. I was up untill 11:30 every night this week preparing all the parts.
Cross member was powder coated.
Front swivels - rebuilt, primed and painted.
Shocks, blasted, primed painted.
Coil springs - GT, blasted, primed painted a pretty Red metallic
Calipers, blasted, primed painted with high heat primer and silver
GT sway bar, blasted, primed painted.
New links.
New bump stops & spacers
New bearings and seals
New cross drilled rotors
New brake pads
New brake hoses and hardware - Reused the coils around the hoses.
All urethane bushings with stainless sleeves, cross member and suspension.
New Grade 8 hardware.
Steering Rack - Cleaned painted and filled
New rack boots
New Tierod ends.
All other metal parts blasted etch primed and painted.
Tire re-balanced and front end aligned - Really neat machine.
Probably more stuff I forgot mention. There is a little touching up to do as a few scratches occured while installing. In looking at the pics, I need to add the small clamps on the boots. The body needs to be cleaned up a lot and that I'll start thinking about next.
Stops on a dime and really handles well. Took it on the highway and it runs straight and solid. Twisties are really, really nice.
New links.
New brake pads
New rack boots
New Tierod ends.
