Front Coil Springs Removal
Gunner
I am starting a front end rebuild on my 1967 Midget. What kind of spring compressor is best to hold the front end up for disassembly? Are there any tricks I should know about?
/ubbthreads/images/graemlins/driving.gif
no spring compressor; yes there are tricks. ;-)
Tullamore
I have taken mine off and put them back on about 5 times in the last six months. I always take out two of the bolts and put in a really long bolt that is full threaded. Then take out the other two original bolts and then loosen the long threaded bolts which lets the spring down through the hole in the a-arm. I can take them off and put them on in about 5 mintues now. Especially if you use a floor jack to help you compress the spring and bracket up a little.
19Sprite65
Having read so many dire warnings of springs flying out to strike the unwary, I wrap and clamp a cable to the spring and A-arm.
spritenut
No compressor. no long bolts, no special tools.
I know the tricks too /ubbthreads/images/graemlins/smile.gif
Jack up the car sort of high, remove the road wheels, Unbolt and support the calipers, don't let them hang by their hoses,
Unbolt the steering arms, or pop off the tie rod ends.
Now unbolt the top shock trunion nut, raise the trunion clear of the king pin and pivot the king pin down as far as possible.
Have a friend hold back on the body of the car, remember it's jacked up quite high, sit on the floor, place your foot on the car frame, grab the spring with your hand and pop it out. It goes back in with a kick of your foot.
As long as the A arm is as far down as possible, the spring has hardly any tension on it. But pulling it out by hand while bracing yourself against a jacked up light weight car could push the car off the stands, this is the only serious concern. I do this all the time. I have removed a spring in a parking lot due to a broken A arm this way, others have seen it.
Tullamore
I tried what spritenut is suggesting just last week when I replaced my worn a-arms. The amount of force that would be needed to pull the spring out with the a-arm down as far as the spring would it go was too much. I was hoping I could just pop it out and back in but no luck, plus this way is a lot more work unless you were planning on taking all of your suspension apart.
I used the long bolt method last time, but it helps to have an air ratchet so that you don't wear out you arm.
sockeyedsushi
Long bolt method and an air ratchet is ideal. I found using fine thread truck spring hanger bolts better than any long course thread bolts. Smoother on and off.
G
Gunner
Thanks very much..
I'll let you know how it works out...
K TR2/3/3A Front coil springs? Triumph 2
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A TR4 front coil springs Triumph 0
PAUL161 T-Series TF Front Coil Springs MG 1
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
PatGalvin Front Coil Springs Triumph 9
PAUL161 Front coil springs MG 1
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
S TR2/3/3A Front coil spring recommendation? Triumph 7
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
KVH TR4/4A Front Coil Spring Spacers Triumph 1
PAUL161 General MG Front Coil Spring Comparison MGB verses a MG TF MG 4
G Choosing the correct front coil spring Spridgets 54
R TR4/4A TR4A Front Coil Spring Replacement Triumph 8
JamesWilson Front Coil Seat Dimensions? Triumph 0
S front/rear coil spring diamaters. Triumph 4
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
