Front Coil Springs Removal
Gunner
I am starting a front end rebuild on my 1967 Midget. What kind of spring compressor is best to hold the front end up for disassembly? Are there any tricks I should know about?
/ubbthreads/images/graemlins/driving.gif
no spring compressor; yes there are tricks. ;-)
Tullamore
I have taken mine off and put them back on about 5 times in the last six months. I always take out two of the bolts and put in a really long bolt that is full threaded. Then take out the other two original bolts and then loosen the long threaded bolts which lets the spring down through the hole in the a-arm. I can take them off and put them on in about 5 mintues now. Especially if you use a floor jack to help you compress the spring and bracket up a little.
19Sprite65
Having read so many dire warnings of springs flying out to strike the unwary, I wrap and clamp a cable to the spring and A-arm.
spritenut
No compressor. no long bolts, no special tools.
I know the tricks too /ubbthreads/images/graemlins/smile.gif
Jack up the car sort of high, remove the road wheels, Unbolt and support the calipers, don't let them hang by their hoses,
Unbolt the steering arms, or pop off the tie rod ends.
Now unbolt the top shock trunion nut, raise the trunion clear of the king pin and pivot the king pin down as far as possible.
Have a friend hold back on the body of the car, remember it's jacked up quite high, sit on the floor, place your foot on the car frame, grab the spring with your hand and pop it out. It goes back in with a kick of your foot.
As long as the A arm is as far down as possible, the spring has hardly any tension on it. But pulling it out by hand while bracing yourself against a jacked up light weight car could push the car off the stands, this is the only serious concern. I do this all the time. I have removed a spring in a parking lot due to a broken A arm this way, others have seen it.
Tullamore
I tried what spritenut is suggesting just last week when I replaced my worn a-arms. The amount of force that would be needed to pull the spring out with the a-arm down as far as the spring would it go was too much. I was hoping I could just pop it out and back in but no luck, plus this way is a lot more work unless you were planning on taking all of your suspension apart.
I used the long bolt method last time, but it helps to have an air ratchet so that you don't wear out you arm.
sockeyedsushi
Member
Long bolt method and an air ratchet is ideal. I found using fine thread truck spring hanger bolts better than any long course thread bolts. Smoother on and off.
G
Gunner
Thanks very much..
I'll let you know how it works out...
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A TR4 front coil springs Triumph 0
PAUL161 T-Series TF Front Coil Springs MG 1
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
PatGalvin Front Coil Springs Triumph 9
PAUL161 Front coil springs MG 1
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
S TR2/3/3A Front coil spring recommendation? Triumph 7
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
KVH TR4/4A Front Coil Spring Spacers Triumph 1
PAUL161 General MG Front Coil Spring Comparison MGB verses a MG TF MG 4
G Choosing the correct front coil spring Spridgets 54
R TR4/4A TR4A Front Coil Spring Replacement Triumph 8
JamesWilson Front Coil Seat Dimensions? Triumph 0
S front/rear coil spring diamaters. Triumph 4
K TR2/3/3A Sticking front brakes? Triumph 9
Z 3000 Front Wheel Bearings Austin Healey 3
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
Z Front Springs Removal Austin Healey 3
Z Front Shocks Austin Healey 19
T TR2/3/3A tr3 front carpet replacement Triumph 5
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
crispy BJ8 Front Suspension Austin Healey 9
B Bent frame rails near BE front end Spridgets 2
K TR2/3/3A Front Hub and Felt Seal Triumph 1
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
F TR2/3/3A front body mounts Triumph 7
8 Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
R Wanted WTB TR-3A front bumper brackets [pr] Triumph Classifieds 6
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
R TR6 Front suspension fulcrum pins Triumph 6
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 2
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B MGA Front bumper solution!! MG 1
Upland Mark IV front suspension Spridgets 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
steveg Picture needed - front turn light Austin Healey 4
S TR2/3/3A Front Suspension Triumph 6
R TR6 Proper alignment of gearbox front cover plate Triumph 3
J Front Suspension Rebuild Austin Healey 16
I Bug eye front disc brake conversion. Spridgets 5
B MGA Sealant for front plate? MG 1
RAC68 Front Seat-back Angle Austin Healey 14
nichola TR6 Transmission front seal replacement question Triumph 8
