Gundy
Installed the new Smiths today. Easy as pie.
The programing was a hoot. The tach needle
serves as the indicator of cylinder numbers.
1k for each number of cylinders.
You plug in a toggle switch and bump it for number of cylinders.
I just had to bump it to 12 for giggles.
Back to 4 before I fired her up.
Disconnected the toggle after programming.
Very steady movement. Fluid motion.
Did a couple of 7k run ups on the way to topping off the tank.
Look out CMP.
Look out CMP.
Hi Guest!
