Forward opening hood / bonnet
Stan Kowznofski
Has anyone ever done a forward opening hood / bonnet for a Midget Mark III? I've seen the ones where the entire front end tilts forward but I am referring to just the "sheet metal engine cover". This would give the benefit of better headroom & accessibility without the complication of extending the wires to the lights and horn.
vping
Bronze
My son and I are building a Midget and I like this idea better. We were going to try and weld the front end together and have the whole thing tilt like my Bugeye. This one is much more simple and I think I can fab the latching mechanism easier as well.
RickF
Larry's design works well, but doesn't leave room for the stock grille. You might want to try to redesign the hinges.
Rick
iceman
Rick
Hi Rick, yes, you would have to cut into an OEM grill to make it pivot correctly. However, I like the look of an open, uncluttered air intake so it was not a consideration for me. One thing I would like to point out for those considering pivoting hood assy from a BE or the later cars, from the frt bottom, is you don't gain an open area to work on the engine. The Wings get in the way just like they do on a BE hood pivoted from the frt. With my mounting, the whole engine bay is open to work on, better on the back as well! My car is a 72 model, with only the hood pivoting, the fenders are still mounted in the normal position.
RickF
Hi Larry,
I have to disagree. My race Bugeye has a stock steel bonnet that is hinged to tilt forward. The access to the engine is way, way, WAY better with the bonnet hinged forward compared to my street Bugeye with it's cowl hinged steel bonnet. The bonnet on the race car is almost straight up and down vertically when opened and the only thing you can't easily get to is the front of the radiator.
vping
Bronze
I did a pretty good job with the BE. Hood fully opens with loads of room to work on the engine. I can probably figure something out for the Midget to give really good access. Mind you not as good as the BE.
vping
Bronze
I think my signal lens are about 1/2" the ground.
S
Stan Kowznofski
I would love to do the same thing with my Mark III Midget but it seems rather complicated which is why I am leaning towards just the bonnet and not the entire front end tilting. Does anyone have any tips, tricks, suggestions, procedures, etc. on what is involved, particularly from the standpoint of lengthening the wiring harness and how to keep it out of the way when the bonnet / fenders are closed. What kind of connector is recommended to be used so the bonnet / fenders can be removed if need be? How much does the harness need to be extended?
Jim_Gruber
A 6 conductor GM Weatherpack Connector M/F Plug will work quite nicely. Comes with Pigtails if you pick the correct one and simply splice in the connector. I've also used a Trailer Harness Connection before.
P Brakes lock up when rolling forward Austin Healey 4
simon1966 Happy New Year. 463 BEV has a lot to look forward to. Austin Healey 5
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
Jim_Gruber Bugsy -Moving forward - RF Suspension is out Spridgets 3
F Seal between transmission tunnel and the forward bulkhead Austin Healey 7
N BJ8 Noise when going from reverse to forward Austin Healey 2
WillR MGB 1 step forward 1 step back? MG 4
D Paying it forward sharing the passion Austin Healey 10
Mickey Richaud Forward Control, Anyone? Other Cars 2
Westfield_XI 2 steps forward, one step back Spridgets 14
aeronca65t Land Rover Forward Control Rover / Land Rover 0
regularman Have you converted to a forward tilt bonnet? Spridgets 32
Trevor Jessie Different type of forward tilt. Spridgets 5
Trevor Jessie Why I'm looking forward to 50yrs of Midgets... Spridgets 65
John Moore Best BE Tilt Forward Unit Spridgets 1
drooartz Tunebuggery Day 5: 1 step back, 2 steps forward Spridgets 4
TonyPanchot lifting of forward covering on esprit Lotus 2
Tinkerman TR2/3/3A TR 3A Passenger Seat Tilt Forward Bolts Triumph 3
C Another forward tilt hold down question Spridgets 5
Brosky Body shop Latest, forward progress Triumph 7
Hooper11772 One step forward ...two steps back! Spridgets 18
JPSmit one step forward four @#$%* steps back Spridgets 16
sparkydave Giant steps forward in customer service MG 0
healeyboz forward tilt Spridgets 22
healeyboz forward tilt Spridgets 7
Jim_Gruber Forward Tilt Bonnet and Wiring Spridgets 8
TexasSprite One step forward, two steps backward Spridgets 5
jlaird Two forward, one back Spridgets 6
B Forward Tilt Bonnet Spridgets 52
JPSmit One step forward - and one step nowhere Spridgets 10
regularman Three steps forward.... Spridgets 21
T Bugger - now the score is 2 forward, 3 back Triumph 11
T Two steps forward, one step back Triumph 2
S Two steps forward, one step back Spridgets 8
ecurie_ecosse One step forward,two steps back! Spridgets 6
healeyboz one step forward two steps back Spridgets 21
mrstinson One step forward, ten steps back - HELP! Spridgets 11
john_j Top Gear - something for you to look forward to... Spridgets 15
EMGEBE Restoration pushed forward MG 8
I TR2/3/3A TR3A - Forward Lighting Triumph 6
cdsmith "Tilt forward bonnet" hold-down question... Spridgets 7
60BN7 Rear Wheel Opening Austin Healey 9
Guido36 Healey Exhibit Opening in Warwick Austin Healey 4
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
M opening classified ads FORUM Navigation Questions 2
maxwedge5281 gas filler opening replacement Austin Healey 4
D BJ8 hood opening Austin Healey 3
S TR2/3/3A grill and apron opening Triumph 18
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
P Can I have door remote opening mechanisms refurbished? Austin Healey 1
