Brosky
This whole setup is being to aggravate me a bit. I have spent way to much time aligning carbs and intakes to make this work. I can just imagine a person with less knowledge, tools, time or patience trying to get this to work properly.
I just tried resetting everything again in the cold mode and ran it until warm and saw no issues, except that on occasion, the idle will wander up about 150 rpms and then will drop.
I'll let it cool down completely for the afternoon and try it again after I get home tonight and see how it reacts. Hopefully, all will be well and I'll go down to Erik's and use his sniffer to tweak in the mixtures, just to be sure.
As far as the spring, on the occasion that I find the idle up a hair, I can push the linkage back ever so slightly and it drops back to the normal setting, so it's not constant, but an erratic hangup that the on carb throttle returns and the factory style spring on the lever, will not override.
