YakkoWarner
I heard back from Moss about the question of why my new flywheel only has one locating dowel hole whereas my old one (and engine) have 2.
According to Moss, the factory DID change to using only one locating dowel at some point, and therefore the flywheel is technically the correct part, and they indicated that the proper procedure for installation is to remove one of the locating dowels from the crank.
So my NEW question is, has anyone ever actually tried to remove one of those? Is it possible to do so without using heat (which could melt/destroy the rear main seal) or getting totally medieval on them with some sort of chisel/hammer (which could destroy the main/thrust bearings)? The man at Moss seems to indicate they could just be rotated/pulled on with an aggressive vice-grip, but that sounds almost too easy....I feel like there's got to be a complication somewhere because nothing involving installing this particular part has been that simple.
Hi Guest!
