Float Level for HD8, BJ8 carbs
shorn
Can someone tell me the correct adjustment for the float hinged lever for an HD8 (BJ8) carb. I know you can place a drill bit between the float chamber cover and the hinged lever, but I can not remember the drill bit size for the HD8 carb adjustment. 7/16??? maybe. Don't have my manual handy and had a leaky float.
Looks like 1/8"
Yes 7/16" drill bit is correct for the HD8 carb.---Keoke
I been tellin you bout reedin them books--Keoke- :laugh:
Thanks,
Used the 7/16 drill bit; only dropped the needle onto the garage floor twice, but found it both times. Turned out to have rust in the bottom of the float chamber. Ended up changing the fuel tank (I had a spare) and adding a fuel filter.
Then I noticed the outer rear muffler had rusted out, so I changed both of them. A little trouble getting the inner off the tail pipe, but finally prevailed with a cutting wheel.
Bottom line, it must be Spring and time to find Healey chores.
It's Fisherman's Disease. Everyone who meddles with old cars gets it. I met a guy today whose passion is old VW Beetles - he's got it bad.
Is the adjustment with the lever the same if you use the ball type needle?
:yesnod:-Keoke--- :smile:
