DerekJ
Many moons ago I removed the original grille and replaced it with a wire mesh, probably for looks but also saved a bit of weight. I was contemplating re-fitting it and took a look at what might be required. I guess the top three tabs on the grille attach to the same bolts that hold the eyelid piece of trim. Is that correct?
My problem is the what do the bottom three tabs of the grille attach to. Looking at the bottom of my shroud there seems to nothing that I could attach the grille to. About 5 years ago I had a couple of offs which re-arranged the shroud and it needed a lot panel beating to get it to where it is now, maybe the fittings disappeared during that work. I had the wire mesh at the time so it wasn’t an issue.
So question is, what do the bottom three grille tabs actually bolt on to?
