Hello All,
I have recently picked up an all original 61 Tr3a with 54k miles that has been sitting in storage for 20+ years. Upon getting it home and in the garage i set to work rebuilding the brakes and filling what little rust I have in the floorpans. The only holdup now seems to be the engine. It is not fully seized but it will not rotate in either direction more than 1/8 inch when i grab the fan, i can feel that all pistons move up and down minimally when the engine is turned that 1/8 inch. reading other posts on here i decided to try the blend of Automatic Trans Fluid and Acetone, but again to no progress. I Have loosened the rocker assembly and ascertained that it is not a stuck valve. I have taken the starter out and that is not the issue. the transmission seems to shift into and out of all gears fine, though it does seem to have a stuck clutch. Honestly i am at a loss for what could be seizing the engine. Is It stuck rings, a tappet, or something all together different that I am not thinking of?
Any suggestions would be greatly appreciated being as this is my first TR! I will flll in any details i have left out as they become relevant.
What Justin said.
