whats the trick to removing the c-clip holding the first motion shaft bearing...that little lip that surrounds it wont let it open but a little....zimmy
The clip can't be removed with the bearing installed. Pull the bearing forward towards the bellhousing to remove, then you should be able to use a screw driver to walk the snap ring off. Sometimes a pair of external snap ring pliers can be used, but it a pain since there are no ears.
hhaha! beginners luck Alan!
i hope u guys are right...ill try to tap it out from the other side.....
it stayed there so i assumed the clip was holding it in!
my snap ring pliers are worthless as it sits....
wish me luck, eh ; ) .........zimmmmmy
ps...is it safe to reuse a "slighty" imperfect snap ring
or should i order new ones and wait it out?
tapped it right out! good work boys ; )
the clip came off without incident, but
another clip ive removed is a little bent...
dont remember exactly where it came from
right now tho.....
