first motion shaft bearing clip
zimmy
whats the trick to removing the c-clip holding the first motion shaft bearing...that little lip that surrounds it wont let it open but a little....zimmy
Re: main bearing clip
C clip ??
Zimmy:
Do you not have a Factory Service PARTS Manual Reprint?? /ubbthreads/images/graemlins/confused.gif
There is no "c-clip" in the bottom end /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/confused.gif
Can you take a pic?? /ubbthreads/images/graemlins/iagree.gif
Ed
uh, its the first motion shaft bearing, my mistake....
some call a c clip a snap ring....how do i get it off?
With a set of duckbill expanders... don't ask me what they are actually called. I'm not a real mechanic... I just play pretend on the weekends.
The clip can't be removed with the bearing installed. Pull the bearing forward towards the bellhousing to remove, then you should be able to use a screw driver to walk the snap ring off. Sometimes a pair of external snap ring pliers can be used, but it a pain since there are no ears.
All right...I've built at least a hundred waffle boxes over the years . How did you get the FMS out and leave the bearing in place?
Alan T
hhaha! beginners luck Alan!
i hope u guys are right...ill try to tap it out from the other side.....
it stayed there so i assumed the clip was holding it in!
my snap ring pliers are worthless as it sits....
wish me luck, eh ; ) .........zimmmmmy
ps...is it safe to reuse a "slighty" imperfect snap ring
or should i order new ones and wait it out?
Unless you break it or strech it too much is should be OK to reuse. As long as it is tight to the new bearing you are fine.
tapped it right out! good work boys ; )
the clip came off without incident, but
another clip ive removed is a little bent...
dont remember exactly where it came from
right now tho.....
