TR4/4A First milestone in the TR4A restoration
Sarastro
I just pulled the body off the frame. I replaced the floors and rockers with the body in place, to be sure everything stayed in alignment. But somehow, it just didn't seem like I was making progress; there was no dramatic, immediately visible change. Now there is.
I made the cart so I could access both the underside and topside easily. I'm glad that I got a set of good casters; I can move it around effortlessly.
The chassis is now in the garage; I've removed the engine and transmission. The main job now is cleaning off a half-century of crud.
Steve,
That looks like you're making great progress...can't wait to get to that point on mine!
Rut
Great work!, question, did you install/weld the rockers in first and then the floors after; or did you assemble/weld the floors and rocker panels first and then offer them up as a unit to the car? Which way works the best?
Looking great Steve. It's always exciting to get the body off!
Cheers
Tush
I think you have to do the floors first, because the inner rocker is actually part of the floor. If you did the rocker first, you'd have to weld the lower edge to a piece of material that you would later remove, and that, of course, doesn't make much sense.
If anyone is really interested, I have a site describing the restoration: https://www.nonlintec.com/tr4a/
I've been working on the frame, and at this point it is clean and ready for some simple frame mods. I plan to spend Saturday doing that, and then starting to paint it. Clearly, I need to get some paint on it fairly quickly, or I'll have more rust to deal with. Once the frame is finished, I can start installing parts onto it. That's another milestone: the point where parts start going back on.
Meanwhile, I'm having more fun with this than anything I've done in a long time.
Hello Steve
That is a great site showing all the steps in your restoration. Going to bookmark it for reference.
David
Steve,
Your usual attention to detail is showing again!
Rut
