(sorry in advance for the long post)---After 7 years I got the new motor in and started, basically Im running what I did before---3 webbers, 10:1, roller rockers and headers. Other than the rebuild the only thing different is bored .040, GP2 cam, light flywheel. I started it up using Rotella and GM E.O.S oils, ran it at 2000 for 20 min., it runs and sounds good.-------Only one small problem, it is running hotter than what it use to,--before the guage hovered at the 1/2 mark now it is between 1/2 and 3/4, that seems a little hot to me. what I did notice is that the water seems to be running through the (new radiator) alot faster than it use to--it looks too fast. After checking a few things here is what I found, the old water pump has a 3/8 pulley that is 4-5/8" in dia. the new water pump has a 4" pulley. Whats up with the different pulley diameters??, they are both 3/8 except my old one has a double pulley and my new one is single. I think a bigger pulley will slow the water down and allow it to cool like it use to??---any thoughts on this. ---Well after a long delay and part restoration it looks like I will be back on the road.
