Re: Finially--new motor started, water pump proble
hondo402000 said:
I would be more concerned about your run in procedure, I have read some interesting sites that say if you run the engine too long at the initial start up with out loading and unloading the rings they will not seat and you will not get the most power out of the engine, and once you wear the hone off the cylinder walls the rings will never seat properly, do a search on running in a new engine
There are two main objectives of run in.
The first & most important if you have a new cam & lifters, if they are flat tappet, is to get the two properly mated together. The generally accepted procedure is to start the engine immediately, everything ready to go, no stops to fix leaks, retiming, etc. Run the engine at 2,000 to 2,500 rpm for 20 to 30 minutes. The extra splash lube from fast idle is vital to the cam & lifters. If they are scuffed during this first run, they will never recover, & continue to wear. The type of oil used during run in is critical, but is a different subject.
After this initial run, drive the car at varying speeds & loads to get the rings seated if needed. Different ring materials require different cylinder hone patterns & roughness. If everything is correct, the major ring seating will happen in a very short time. A good engine machine shop will know what hone pattern to use with which ring materials.
On a new engine that I recently built, I did a 40 minute fast idle to mate the cam & lifters. The first 20 minutes of this run required supplemental cooling to keep temps down. A garden hose in the radiator filler & a block drain open. After the first 20 minutes the water temp started dropping rather quickly. A sure sign that the rings had seated & no longer blowing combustion heat past the rings & into the cylinder walls. The supplemental cooling was stopped & the engine run for an additional 20 minutes to make sure that the cam & lifters were mated.
A quick hot compression check was done, all cylinders at 190 psi.
The engine was left to cool to room temperature & head bolt, engine bolt torques were verified.
Additional running has been at varying speeds & loads to complete any additional ring seating that might be needed. Additional compression checks, both hot & cold, over the next 700 miles have shown no change. Additional verification that the rings had seated in the first 20 minutes of run in.
If you think about it, race engines hit the track pretty much ready to go. No such thing as prolonged break in. If the rings don't seat quickly, it's not likely that they will seat more later. It's all in the cylinder hone pattern/roughness/ring material equation. With iron rings, no oil is used on the rings during assembly. Only a light smear on the cylinder walls which is mostly wiped down as the piston/ring assemblies are inserted into the cylinders.
There are other ways to do this, I'm only describing the way I've always done it. Obviously, different ring materials require different cylinder prep & possibly different break in. All new flat tappet cams & lifters require the same break in procedures.
