Filling shocks
LLAngus
Hi gang. Was able to work on the GT this weekend. The windshield wipers quit--took apart the switch and found the metal thingy (JB copy righted) was bent. I was able to rebend it into the right shape and reinstall. The curtisy light quit and in the investigation of the wipers found a blown fuse. Replaced the eight rear spring bushings--found out the front ones don't come in the "kit". Now for the question--my car sits low in the rear and I want ot fill the shocks with oil (car sat for over two years before I got it). Do I jack up the body to put height in the suspension or just fill it as best as I can from the "level" position? Also found a RB Midget at the local wrecking yard. Main body in good condition-- motor, trans there. Needs trunk lid and interior work. What is the highest amount to offer? Car is white.
/ubbthreads/images/graemlins/driving.gif
$50-500 on the midget, no more than that. The engine will need rebuilt/replaced, and interior kits are about $1500-2000. Tony might have a bootlid for cheap.
vping
Bronze
Wave $200 in his face and see if he bites! Keep an extra couple $10's in your pocket in case ya gotta hagle. Worked with my GT 10 fold.
PaulP
On the shocks, it's not going to matter what position they're in when you fill them. Use 20w hydraulic fluid. You'll find the filler bolt is between 1/2" and 9/16". I understand it's actually a 1/4" Whitworth bolt. A filed 13 mm works.
Platinum
[ QUOTE ]
[/ QUOTE ]
A six-point 14mm socket can work in a pinch if the plug hasn't been beat up too much. Those filler plugs are about the only Rudge sized fittings on the car.
L
LLAngus
So how full do I fill them? Also, Dr. A, I changed the rear bushings and it has made a difference in the handling of the car. I need to change the rear sway bar bushings. It has a wear mark where it is hitting the shocks(?). Again, thanks to you and Tony for all the advise.
Platinum
As full as you can get 'em. Replace the plug, drive around a bit (Good excuse!) or "bounce" the car for a bit, "burp" them (CAREFULLY remove the plug: it'll want to spit in yer eye!) and fill a bit more.
X
xsteamer
Nobody mentioned in the previous posts how to access the filling plugs for the rear shocks, so I will. Remove the carpet behind your seats and it should reveal a plastic plug either side of the battery cover. Remove them and you can access the rear shock filler nut/plug. Also I read somewhere that 50 weight hydraulic oil works good.
tony barnhill
Great Pumpkin - R.I.P
Used trunk lid - $50
Mack
Hello, PaulP mentioned 20w oil, I thought the shocks should be filled with 90w? And on that subject, I saw some 85-145w oil the parts store, how would this work for shock oil? would it make a stiffer ride? no difference? or would it be harmful? Thanks, Mack
Platinum
Not a good idea for anything much more than 50w... and that's a bit stiff. 20w motorcycle fork oil is appropriate. Mineral oil works too, but a bit stiffer.
I'd be wary of aught but mineral based oils. Just my opinion.
sparkydave
Never heard of using 90 weight oil. The shock oil you get from Moss is 20 weight, and seems plenty stiff. I discovered that the lever shock damping is adjusted by changing the valve body in them, not changing the fluid, and I wouldn't go using "any old oil" unless you were really sure it's not going to damage something.
PeterC
It is possible to over fill the shock, which when the oil gets hot will cause the oil to leak as it expands. The rasied bit on the rear shock lid, and on the front, is meant for that expansion. 90W is a no-no, there is a 2-way valve, the main valve under the 7/8" cap, and a poppet valve in each piston. Heavy oil will somply not flow properly, and will usually cause the rocker splines to strip, or the poppet valve ball to get loose. The 20W oil, in and otherwise servicable shock is more than enough. If I read the start of this thread correctly, it is that you are hoping to raise you car by adding oil. It wont. Shocks do not support weight nor alter the ride height. They "merely" dampen the oscillations caused by the road springs and/or the tires. Hope that helps. Peter C.
Platinum
I was trying to be "diplomatic," Peter. /ubbthreads/images/graemlins/grin.gif
PeterC
Ah, ahem, yes... diplomatic.. got it.
lessee
OK, Got it.
Try to stick with the recommended lubicants.
How's that? ;-) (where the heck are the emoticons y'all are using? I'm newish here.)
Platinum
They (emoticons) *should* be just below the field you enter the text.
I've seen stripped splines, bent vertical links and even a broken lever arm from using "heavy" oils in these shocks.
T Filling rear Bugeye shocks - any tips? Spridgets 7
D Filling Holes Austin Healey 21
steveg TR6 Cooling system filling Triumph 7
S Filling Steering Gearbox with Castrol Hypoy Process Austin Healey 10
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
T Filling an Armstrong Lever Arm Shock Spridgets 0
T Filling for an Armstrong shock Spridgets 1
Gearhead_Garage Fuel backup while filling Austin Healey 24
D Location of gearbox/transmission filling area Spridgets 12
N Filling holes??? Spridgets 16
H TR6 Filling up the TR6, overflow? Triumph 6
T filling/flushing steering rack Spridgets 7
T Revised fuel tank filling strategy - re ethonal Triumph 5
TRMark TR4/4A Shorten the radiator filling neck on a TR4? Triumph 7
T over-filling the gas tank Austin Healey 30
R Filling overdrive oil on BJ-7 Austin Healey 5
BOBBYR Filling my O/D transmission Austin Healey 8
CCURTISS TR2/3/3A Filling TR3 Steering Box Triumph 10
B Filling SU Dampers? Spridgets 20
A Filling Coolant Spridgets 6
G Checking & filling shock absorber fluid Spridgets 9
Johnny Filling differential Austin Healey 4
DerekJ Gearbox oil level and over-filling Austin Healey 11
G Filling a completely dry cooling system.... Triumph 13
M Filling up with Gas MG 11
R question on filling rear shock....[armstrong] MG 3
Obtong Filling Steering Rack/Boots MG 6
K Filling a grease gun Restoration & Tools 9
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Gliderman8 TR6 New shocks (damper) question Triumph 4
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
D The best place to get shocks rebuilt. Spridgets 8
J Midget front shocks Spridgets 4
W Best source for Bugeye front shocks Spridgets 3
AngliaGT My '95 Dodge Dakota Needs New Shocks Other Cars 4
Michael Oritt Shocks and/or Springs Austin Healey 9
Z Front Shocks Austin Healey 19
P TR6 New front shocks & air in clutch Triumph 15
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
A Front Shocks Bushing Replacement Austin Healey 2
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
JPSmit replace shocks in pairs? Spridgets 7
P TR6 Front shocks Triumph 11
nicko Front shocks Austin Healey 16
Rut TR4/4A Bilstein shocks Triumph 0
maxwedge5281 Koni Shocks Installation Austin Healey 18
S TR2/3/3A New shocks too short? Triumph 7
