My first preference would be lead filler. But it takes a little practice to get it right. The easiest way would be to work in some All-Metal body filler. I had similar gaps on my midget, but the poly-fill primer actually closed the gap. Do you have some feeler gauges that you can measure how much gap we are talking about?
lead filler is a good idea, it is malleable so maybe wont just crack out. I've never used it though, and don't know where it is available.
I saw some Bondo "metal fill" at autozone the other day ("aluminum reinforced body filler").
What type of "all-metal body filler" do you recommend?
Gap varies along the bead from almost no gap to maybe 40 thousandths or so at it's widest
I was thinking about something similar to the 3M for small gaps around my headlamps before I repaint my Bugeye. I assume this is somewhat similar to seam sealer,but is paintable, correct? Jim
Paintable seam sealer works well. Just scrap off the excess to leave a nice edge before it sets. You don't want it to look like a caulked seam with rounded edges.
