Fender beads look kinda lousy, sealer?
TulsaFred
I primed the car but before I paint I'm wondering about the fender beads.
The paint shows cracks intermittently along the sides of the beads.
What do people do with this,
just accept it, or is there some kind of sealer that can fill the gaps?
thanks
Fred
Do you mean you can see the gap between the bead and the fender, or that you can see cracks in the paint?
If you are seeing cracks in the paint, then it is time to start removing paint.
TulsaFred
TulsaFred
no it's the gap,
The paint bridges the gap discontinuously so it looks crappy
paint was removed down to bare metal before priming
Fred
OK.
My first preference would be lead filler. But it takes a little practice to get it right. The easiest way would be to work in some All-Metal body filler. I had similar gaps on my midget, but the poly-fill primer actually closed the gap. Do you have some feeler gauges that you can measure how much gap we are talking about?
TulsaFred
TulsaFred
lead filler is a good idea, it is malleable so maybe wont just crack out. I've never used it though, and don't know where it is available.
I saw some Bondo "metal fill" at autozone the other day ("aluminum reinforced body filler").
What type of "all-metal body filler" do you recommend?
Gap varies along the bead from almost no gap to maybe 40 thousandths or so at it's widest
Fred
I was thinking USC All Metal, but someone else may have a better suggestion.
nomad
I just used 3M body putty. The stuff that comes out of the tube looking like thick paint. Worked in with a plastic sqeedgee.
Kurt.
jlaird
I would also think hard about 3M body putty.
Jimflorida
I was thinking about something similar to the 3M for small gaps around my headlamps before I repaint my Bugeye. I assume this is somewhat similar to seam sealer,but is paintable, correct? Jim
sqbsprite
Paintable seam sealer works well. Just scrap off the excess to leave a nice edge before it sets. You don't want it to look like a caulked seam with rounded edges.
Rob Glasgow Fender Beads still in wrapper Austin Healey 5
R TR2/3/3A Securing the front fender beads Triumph 11
T Stainless Steel Fender Beads Triumph 1
J TR4/4A Installing new fender beads on TR4 Triumph 1
TulsaFred Fender beads Spridgets 12
M Rear fender beads Jaguar 10
C GT6 GT6 fender flares Triumph 0
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
R Fender Spear Potential Rattle Austin Healey 6
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
5 TR2/3/3A TR3 fender patch panel question Triumph 10
H TR4/4A Fender/Wing repair how to do Triumph 5
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
M TR2/3/3A TR3 Small Mouth Inner Fender Holes Triumph 3
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
K TR2/3/3A TR3's without the fender mirrors........... Triumph 6
1 TR3 Fender spats sold on EBay. Triumph 5
K TR2/3/3A Passenger side fender mirror....... Triumph 13
BoyRacer Rubber Fender Buffers Austin Healey 2
vette MGB Rear Fender Dog Leg Patch Panel MG 3
M TR2/3/3A Front Inner Fender Doublers Triumph 2
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
Boink Fender seam annoyance... Spridgets 4
D TR2/3/3A rear fender bead Triumph 2
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
R TR2/3/3A Not for the faint of heart: Fender Horror Show Triumph 46
D Wing Fender Fitment Question Austin Healey 6
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
L TR2/3/3A Scuttle / front fender attachment Triumph 9
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
DornTRoriginal TR2/3/3A Fender Bead Installation Triumph 10
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
S T-Series front fender MG 1
I Wanted 69 TR6 fender Triumph Classifieds 0
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
K TR2/3/3A TR3 Spats?...Fender Skirts. Triumph 3
R Fender bolts Austin Healey 10
aero3113 1956 100 BN2 Fender Beading Austin Healey 8
maxwedge5281 aluminum fender vents installation Austin Healey 14
D fender spear Austin Healey 23
Rut TR4/4A Fender beading mounting tabs Triumph 3
Rob Glasgow Help with fender bead Austin Healey 26
O Need front driver's side fender 65 Midget Spridgets 0
T TR2/3/3A Is there a way to get more clearance between tires and back fender on TR3A? Triumph 10
B TR2/3/3A seam sealer front fender and cage muts, undercoat Triumph 7
B TR2/3/3A Rear Fender Part Triumph 3
DornTRoriginal TR2/3/3A Stone Guard and Fender Fitting Issues Triumph 6
S TR2/3/3A tr3 front fender Triumph 4
