TR2/3/3A Fan belt
GeneW
Have always used NAPA 25-24379 (Gates TR24379) fan belts on my TR3 with the stock fan and generator pulleys. Purchased a new NAPA 25-24379 several weeks ago and ran out of belt tension adjustment before the new belt was tensioned. The cardboard sleeve for the new belt gives the outside circumference as 978mm (38-1/2ā€) and the top width as 17mm (21/32ā€). I still had the cardboard sleeve from the old belt (don’t ask why…) and the sizes are listed as circumference 976mm (38-3/8ā€) and the top width as 19mm (3/4ā€). So the new belt is 2 mm larger in circumference and 2 mm smaller on the top width. The combination of the two dimensional changes on the new belt made it impossible for me to tension. I did purchase a NAPA 25-28386 (20mm x 996mm) belt but have not tried that option yet.
I did have a belt from The Roadster Factory, purchased several years ago, which was part # 58924 and is an Optibelt-VB and sized as 20 x 900. Only Superman could install that belt. If you are carrying the Optibelt belt as a spare in your boot (trunk) and don’t carry a 6 foot long crowbar to pry it over the pulleys you will be crying when you try to install it on that cold, moonless night when your belt breaks.
Do you think they would work if you unbolted the generator to install them...or are they even too tight for that?
I recently went through that exercise because I changed to an alternator. What I found is the width of the belt has more of an effect on the fit than the length. Because it is a V-belt, the 'working length' has a bigger variance with width changes. And remember, the generator belt does not need to be very tight. Too tight a belt will quickly ruin a generator and/or water pump. -Still when I had a generator, I had to loosen the generator to get the (correct) belt around the pulley. -Although you can start a cog on the pulley, and use the hand crank to turn the engine over to pop it into position (sort of like putting a chain back on a bicycle).
I believe one could get the Optibelt on if the generator was unbolted but I have such a hard time accessing one of the generator mounting bolts that I would dread having to remove the generator to replace the belt. The Optibelt is not a cogged belt so it was tougher for me to work the belt into place. Both NAPA belts are cogged and seem more flexible.
The wider NAPA belt (25-28386) does ride quite a bit higher in the pulley at what I would consider the "normal" spot a belt should ride in the pulley. That being said, I never had any problem with the narrower NAPA belt (25-24379) even though it was riding pretty far down in the pulley. It was also easy to install as the generator could be pushed toward the engine enough to install the belt and still have enough travel to tension the belt.
I would agree with the belt tension observation. I run my belt pretty loose and have had good luck with both generator and water pump bearings.
I purchased Moss's "better" cogged replacement belt,(834-025) and their alternator conversion. However it was impossible to mount the alternator because the belt was too short. I am waiting to see what Moss's technician suggests. It sounds as though a generic belt might be the solution, but which one?
1960 TR3A, 60014
1960 TR3A, 60014
All of the belt manufacturers and distributors publish very detailed specifications. To get a perfect fit you still might need to loosen or remove the gen/alt.
Tom
Working on a recently acquired 1961 Tr3A. GM Delco Alternator required rebuild. The belt received on the car was a 5L380. I found it impossible to reinstall that belt, simply not enough length. That may be why the PO replaced the water pump just before sale.
Tried the Gates 28386 which was suggested elsewhere, and found it too wide for the original pulleys.
Discovered the Gates B37, which is the correct 21/32 width, and 40 inches long. Simple to install, but takes the alternator against the fender bracket to get the correct slack. 52 miles later, looks good.
Joe Harkins
1953 TR2, owned while in college 61 years ago
1961 TR3A, current driver
Hey Joe,
The "original" belts were an extra wide version, used on the original dynamos. If you have the alternator modification, then you will likely need a more modern, narrow belt. The length will depend on your particular alternator mod that the PO did.
As you can see in the pics, the Gates B37 is an exact width fit for my Delco alternator. The alternator is rotated as far from the engine block as it will go, to accommodate the extra length. Posted this to help others who may have difficulty installing the belt. B37 is 21/32 x 40.
Gene, I went to the brighter side for my ā€˜59 3A, several years ago and replaced the generator with a bolt on alternator kit supplied by British Wiring, a division of the Triumph Rescue in Bally PA. The kit was complete with excellent instructions and included a new belt to replace my generator belt. That belt was a 25 34379 and it fitted perfectly after the install. I carry a spare and have kept the original sleeve. The size of the pulley on the alternator may be a factor in belt size. OD on mine is 2.5 inches and measures 7/8 inches shoulder to shoulder. When the belt is in place it sits below the outer edge of the pulley.
I note that no one in this thread mentions that getting a new belt on is significantly easier by getting front wheels off the ground and turning wheels full lock to the right. This opens the gap between the control arm away from the lower pulley enough to get the belt onto the lower pulley. Hope you get it all sorted out.
Frank D…..
Hey Joe,
It is perfectly possible to replace the generator with a modern alternator and retain the wide belt.
Hi
Stock TR4A with original generator and cooling fan. Running a NAPA #NBH 25-28386 (manufactured by Gates)/ Gates #TR28386 - cogged belt for last 10K miles. Got it from local NAPA store.
