Failed Texas Kooler Fan
Stretch
For group info I just removed a failed Texas Kooler fan frommy BJ7. One blade broke off, and luckily,only cut through the heater inlet hose. Theblade broke off at the blade root with less than 5k miles. It was installed in 2011. A second blade was broken half way and athird had a tiny crack beginning. If youare using one I suggest regular inspections for hairline cracks at blade roots onthe backside of the leading edge.
RAC68
Hi Stretch,
I have been concerned about that potential for a number of years. I installed my TC in the mid-late ‘90s and have a tendency to shift at around 5K RPMs. Although I have not noticed any stress cracks yet, I am considering putting the original metal fan back in the spring. For now, not being able to drive for a while as the result of a recent throttle foot operation, I will leave it in but take your advice.
I wish you an inexpensive repair,
Ray (64BJ8P1)
IIRC, when a TX Healey Club quit selling the fans Moss, I think, had some reproductions made that had such problems. I've had one of the 'original' Texas Cooler fans--bought from the TX club--for close to 100K miles with no problems.
RAC68
Hi Bob,
I too have a Texas Cooler purchased from the club and see no fractures as yet. My concern is that, over time, stress, and heat, deterioration would begin and, on one of my 5K shifts I may experience what Stretch had. Although the change is not urgent, I will begin to look at alternatives and, presently, do not like the metal flex fans. With all the cooling air flow modifications I have executed, maybe its time to see if the original metal fan performs reasonably.
Ray (64BJ8P1)
Keoke
For group info:
To prevent this failure I have made a 1/2" thick round aluminum spacer that fits behind the fan and has an area equal to the unsupported section of the fan 's hub.
S
Stretch
I am not sure a spacer could have prevented my fan's failure. The blades broke at the point where they joined the plastic hub. Close examination of the cross sections of both broken blades indicates that the plastic broke part way rapidly, then over time continued to tear apart. Perhaps this was caused by internal stresses created as the molded plastic cooled coupled with the sharp angle of the backside joint. If you could post a picture perhaps I could get a better idea if we are addressing the same issue.
Keoke
Keoke,
Can you please post a picture.
Thanks,
Ray (64BJ8P1)
Sorry guys I am not at home now I am in the valley of the sun which is flooded in some parts. But believe me the spacer works.--Keoke
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
T TR2/3/3A Petronix Flame thrower coiled failed after 1-1/2 months Triumph 8
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
richberman failed rear brake cylinder... Austin Healey 1
BlueMax Griffin Failed Miserably Spridgets 14
SCguy Wedge My TR8 failed CA smog! Triumph 9
T Failed ignition points? Triumph 27
J Failed State inspection-tie rod end..follow up Spridgets 4
J Failed State inspection-tie-rod end? Need help Spridgets 8
prb51 Failed Thermostat pics Triumph 3
prb51 Failed sleeved thermostat Triumph 18
regularman Well there's one failed idea Spridgets 20
B Failed Emissions Test - Please Help Austin Healey 21
Z MGB 79 MGB: Failed Emissions... MG 14
RobT Second Failed Ignition Rotor in 100 miles???? Triumph 14
A Emission - FAILED! Spridgets 10
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
Nugget Texas 200 mile road trip success Spridgets 13
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
L The Texas Cooler Austin Healey 10
R XK 150 Texas Repair Shop Jaguar 1
Brinkerhoff "Texas Cooler" fan available? Austin Healey 13
H Texas Cooler or not Austin Healey 23
H Anyone know where to get a Texas Cooler fan? Austin Healey 7
W Texas Kooler Fan Availability? Austin Healey 33
PAUL161 Vintage Racing in Oklahoma & Texas Racing 1
D Texas All British Car Days - Austin, TX - 9/26-28 Spridgets 0
M General TR Austin Texas VTR or TRA car show in April 2015 Triumph 3
H camber plates and Texas Kooler Austin Healey 8
tomshobby General TR Randy [tr4nut] and the Texas FOGS Triumph 3
D Texas All British Car Days - Sunday Sept 29th - Round Rock, TX [just north of austin] Spridgets 5
D Keeping Bondo cool - Texas style Spridgets 1
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
S Texas restoration recommendation? Austin Healey 2
Alphonse NASA - race #3 at Texas World Speedway Racing 0
Alphonse Lotus 2-11 racing in Texas Lotus 3
drambuie New Texas cooler fan by Moss Motors Austin Healey 0
1 Jensen Healey Rear end / Rear Axle wanted -Texas or surounding preferably Other British Cars 6
StagByTriumph Tragedy in Texas Triumph 1
Geo Hahn TR2/3/3A TR3A Heading to Texas -- Yours? Triumph 10
G PARTS FROM ENGLAND TEXAS COOLER FAN Austin Healey 5
R Texas Kooler fan Austin Healey 15
boxofparts Texas car in Michigan for parts MG 6
hilsideser TR2/3/3A TR3 for sale in Texas Triumph 12
drambuie Wanted, Texas Cooler fan.... Austin Healey 0
aeronca65t Race Petition-new F1 track in Texas Racing 0
