Faded Seatbelts
DonJ
47 years have taken their toll on my black seatbelts. Has anyone tried to dye them? If so, how did you do it.
Thanks
dj
LarryK
Might want to replace them as they are 47 yrs. old. They might not hold up to some texter hitting you.
Deleted member 8987
You can, but that wasn't the original question. The links I put up, one mentions a place that does that...cost him $139 for one shoulder belt.
All things are possible with Jaguars once you understand their appetite for one hundred dollar bills.
One of the discussions I read on faded belts is, maybe they are weaker, but at 1% who cares.
Probably the sheet metal they bold to is thinner, too, and will fail long before the belt does.
PAUL161
Seems there was a place named, "Snake Oil", or something like that, that rebuilt belts. PJ
OK, the name is spelled -Ssnake-Oyl!
Deleted member 8987
Tried using rit dye on seat-belts before, and it only looks great from a distance. Your best option is to get a new one.
Apparently reading what is posted is too difficult.
So, I will re-post it (from above) and it will explain why Rit doesn't work. We know that. Acid dye will, so here is the re-post:
Most folks will tell you nylon webbed seat belts won't take a dye. All sorts of "never work" discussions.
Read this:
https://www.g3gm.com/t5945-dyeing-seat-belts
Acid dye...your dye mixed with vinegar.
https://www.jacquardproducts.com/acid-dye.html
DJames
Well it's 2-1/2 years later and I still haven't done anything about this.:wink-new: However I just stumbled across www.safetyrestore.com, who can re-web new belts using the original hardware and buckles. Wondering if anyone has had any dealings with them.
healeyblue
I used safetyrestore on a wreck rebuild I did to reset the airbag module and seat belt tensioners. I have not used them for replacing the webbing but have seen peoples cars who did change the webbing for a different color and the work was well done. They had a fast turn around and the workmanship with my stuff was well done.
K TR2/3/3A Another wiring query...faded wiring colors. Triumph 3
Gliderman8 Faded brake light lens Restoration & Tools 17
Michael Oritt Retractable two-point seatbelts Austin Healey 12
Y MGB Another question - this time on seatbelts.... MG 2
Bantamfan Seatbelts Spridgets 4
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
R TR 3 Seatbelts Triumph 4
CJD TR2/3/3A TR3 Seatbelts Triumph 11
RAC68 Needed - 3-point Seatbelts Austin Healey 10
T 76 midget seatbelts Spridgets 4
brgrmyster Kangol Reflex retractable seatbelts Jaguar 4
brgrmyster TR6 Sourcing TR6 Kangol Reflex seatbelts Triumph 6
Jim_Newman Seats and seatbelts Austin Healey 6
R TR6 TR6 Aftermarket Seatbelts Triumph 4
lbc_newbie Click-it or ticket...78 Midget needs seatbelts! Spridgets 26
Hairyone BE seatbelts Spridgets 1
B Seatbelts - harness' Racing 4
M ^^ Sprite Seatbelts Spridgets 16
G TR6 TR6 Seatbelts Triumph 2
R 3 point seatbelts, attaching? Austin Healey 9
mrv8q TR6 TR6 Seatbelts Triumph 9
Baz MGB-GT BGT & rear seatbelts... MG 11
D Seatbelts and sunvisors MG 24
wingsandwheels TR6 TR6 Seatbelts, opinions Triumph 7
mgbnew Installing Seatbelts [over the shoulder type] MG 3
bash TR6 TR6 Seatbelts Triumph 4
D Seatbelts Spridgets 3
P MGB-GT Help: BGT seatbelts MG 3
G Do seatbelts increase safety? MG 47
coldplugs 1966 S3 Elan seatbelts Lotus 2
V Elan seatbelts Lotus 2
