facet fuel pump never stops ticking.
AH67
Hi guys, I have a facet fuel pump installed. I cannot identify the model number but it is cylindrical Even when the ignition is switched OFF the pump ticks and it never stops ticking. I have to use the battery cut-off switch to turn it off.
Any thoughts?
bob hughes
Power must be getting to the pump, has it always happened?, check the wiring on the ignition switch, is there a by pass lead fitted say for a clock this would give continuous power and if this is mixed up somehow with the pump circuit. It would be a matter of tracing the circuit back with a tester. Do you have an electrical diagram, this would help in picking the points to check.
:cheers:
DerekJ
The fuel pump should be wired directly to the fuse block where it becomes part of the ignition circuit. It should be a white wire. Presumably the ignition switch turns off the ignition without problem? Did this problem just start? Have you just switched to a Facet? When the ignition is on, the Facet will continue ticking and never stop as it has a by-pass circuit built in to it.
steveg
On the fuse block the white pump wire is attached with the white wire coming from the ignition lock at position 3. If it is attached at 1 or 2 it will be hot all the time.
FWIW - cylindrical pumps generally are higher pressure than SU carbs use - suggest verifying this pump with www.pegasusautoracing.com. You may need to add a regulator.
AH67
AH67
yes the ignition switch turns off the ignition without problem. Do not ask why but this BN7 came wired with 2 SU pumps (with toggle switches) and the Facent. I had a bad cut-off switch that I just replaced. The problem was on and off and now on all the time
steveg
If the fuel pump white wire is properly attached at position A3 with the wire coming from the ignition switch, it will go off when you turn the ignition off. Since that's not happening, either the white wire is attached to a hot terminal on the fuse box or the fuel pump white wire has been hijacked for some other purpose and an unswitched separate wire's been run to the fuel pump.
Bayless How do you mount a Facet fuel pump? Spridgets 10
TulsaFred Airtex vs Facet fuel pump Spridgets 29
drooartz MGB-GT Facet fuel pump location MG 11
Lin Facet Fuel Pump Spridgets 18
R Facet fuel pump MG 4
R GT6 Facet Fuel Pump Alternative [GT6] Triumph 4
Sebring222 Facet Fuel Pump Other British Cars 9
athenssprite Facet fuel pump - for use on 1960 BE Spridgets 16
healeynut Fuel Pump - Bendix/Facet Austin Healey 0
C Facet fuel pump Austin Healey 6
roofman Facet electric fuel pump - need advice Triumph 15
Sarastro Facet fuel pump question Spridgets 5
aeronca65t Facet, Purolator fuel pump MG 11
drooartz MGB-GT Facet vs SU fuel pumps MG 18
sparkydave Facet fuel pumps reliable? Spridgets 23
steveg Facet pump - explanation for superiority over SU Austin Healey 13
bugedd Facet pump died Spridgets 18
G Facet pumps any good? Spridgets 23
dklawson Metal vs Plastic Facet Pumps ? Spridgets 2
T Normal for a Carter/Facet pump to be hot Triumph 11
healeynut FACET Square Body Pump Woes Austin Healey 4
AndreL TR6 Conversion to electric fuel pump Triumph 6
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
