TR6 Expansion plug question
nichola
I bought a set of brass expansion plugs for my TR6 but ruined one of the 1 1/2 inch guys, so I ordered a single one of those (for the front of the block). However, it is not as deep as the other plugs. The block is close to 3/8 thick right there and all the other 1 1/2 plugs were about .3445 front to back versus .1995 for the skinny one. Two questions:
1. why does stuff like this happen? (be nice)
2. should I go ahead and use it or look for a deeper one like the others - although I don't know where I'd find it with Moss and VB, etc., closed right now.
My temptation is to go ahead and press it in there with some Permatex #1 (80007) hard drying gasket sealant.
Probably just a different brand. Chances are good that the thinner one would work fine. The Permatex would be some cheap insurance.
Ed
You can get generic plugs almost anywhere. Check ebay, for example.
I have been looking, but will continue. The ones I've found so far are either like mine or .420 deep, which means it will stick into the water passage a bit. Rimmer does sell the ones I'm looking for individually.
Thanks for the response.
