Exhaust Tailpipe Length
warwick-steve
Hi all
Just fitted a new tailpipe to my BT7 but it seems too long. Before I cut something from the end Is there a "correct" length relative to the bumper/over rider?
Thanks in advance
Steve
From my experience, the end of the pipe should extend at least an inch--you remember inches, right :friendly_wink:?--beyond the bumper/overrider above it. If not, you'll get a) residue (soot) on the bumper/overrider and b) possible fumes in the cockpit due to some aerodynamics causing the gasses to 'curl' towards the front of the car.
Worse:
Failure to allow at least 2 Inches past the Bumper will cause the chrome to turn BLUE >Fail
Thanks Guys,
Yes, we do still understand inches over here but many thanks for the conversion!
Well, I guess the tailpipe is OK after all. It measures 2.5inches beyond the bumper and 1 inch beyond the over rider. Just looks much longer than the old one.
thanks again
Steve
Uh, don't forget, the UK uses inches, feet, miles, etc. Where do you think our outdated system came from, after all?:smile-new:
Jack
"Well, I guess the tailpipe is OK after all. It measures 2.5inches beyond the bumper and 1 inch beyond the over rider. Just looks much longer"
Yep! ole Mate you are good to go. :applause:.
Darn it
When I bought my stainless steel set up some years ago now, I cut back my tail pipes to about the bumper line as was the one that it replaced, I also cut them on the splay to prevent rain entering - that was the thinking at the time! Ah well must hunt around for a nice slip over chrome extension.:smile-new:
:cheers:
Go to the plumbing department and look for chrome plated brass pipe used in sink drains. I found some that were a perfect slide on fit, and easily cut. They have been on for over ten years. High temp silicone seal, if needed.
Steve , One thing to check is your vehicle regulations. In south Australia the exhaust tail pipe cannot protrude past the rear extremity of the vehicle, we are over regulated compared to the USA and I hope you aren't as well, but it may pay to check. saltiga
