Exhaust Heat Shield
Ray Smith
Just purchased an exhaust shield for the BJ7. Can someone email a photo showing the correct placement of said item?
Ray
Hi Ray, Which Exhaust Heat Shield are you referring too?. There are several heat shields used in the car that are included to shield heat from the exhaust.--Keoke-??
[ QUOTE ]
Keoke,
It is the one that fits on the floor pan.
Ray
[/ QUOTE ]
So I guess it's the one that goes above the mufflers. There are existing fasteners that line up with the holes in the heat shield to fasten it in place. You can sneak it up into place to check for the correct alignment and a Universal joint will allow you to tighten it in place without dropping the mufflers. Help?--Fwiw--Keoke
