Exhaust Heat Shield
Ray Smith
Just purchased an exhaust shield for the BJ7. Can someone email a photo showing the correct placement of said item?
Ray
Keoke
Hi Ray, Which Exhaust Heat Shield are you referring too?. There are several heat shields used in the car that are included to shield heat from the exhaust.--Keoke-??
Keoke
[ QUOTE ]
Keoke,
It is the one that fits on the floor pan.
Ray
[/ QUOTE ]
So I guess it's the one that goes above the mufflers. There are existing fasteners that line up with the holes in the heat shield to fasten it in place. You can sneak it up into place to check for the correct alignment and a Universal joint will allow you to tighten it in place without dropping the mufflers. Help?--Fwiw--Keoke
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
J Side exhaust heat shield Austin Healey 23
19_again MGB MGB exhaust heat shield MG 3
L remove heat wrap on exhaust? MG 6
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Z For Sale TR-4A exhaust manifold Triumph Classifieds 0
BJ8Healeys BJ7/BJ8 exhaust systems Austin Healey 21
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
AUSMHLY Exhaust leaks Austin Healey 14
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
S TR2/3/3A exhaust Triumph 26
Lin Ideal exhaust note! Austin Healey 7
I Stainless steel exhaust. Austin Healey 5
steveg Curing exhaust drone - Helmholtz resonator Austin Healey 21
M Muffler Options with Exhaust Header Spridgets 1
E Moss stainless exhaust offering. Austin Healey 28
RAC68 Home Made Healey Exhaust Headers from a BOX Austin Healey 15
S Side exhaust system for BJ8 Austin Healey 16
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
K Wanted 100-6 exhaust manifold for two port head Austin Healey Classifieds 0
T TR6 Refinishing Exhaust Manifold Triumph 4
T TR6 Refinishing Exhaust Manifold Triumph 6
AN6-TX Exhaust Smoke Spridgets 15
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
S TR4/4A How to fit exhaust intermediate pipe? Triumph 5
J Exhaust pressure extremely different between pipes? Austin Healey 20
catfood BN1 Exhaust mounting Austin Healey 8
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
TEM666666 Exhaust loud popping: Lean? Rich? Fuel? What else? Spridgets 25
warwick-steve Exhaust Tailpipe Length Austin Healey 11
Darwin Spitfire Exhaust hanger location Triumph 4
