2wrench
Cold. Wet. Rainy. Sucks for doing car work.
Lazy (engine parts still being machined). Little
excitement.
So, let's tell some stories (no lies).
Auto paint shop wanted $3,000 to replace rocker panels
on my '69 Chevy truck. POR-15 paint and fiberglass
for about $60 did the job...$30 a side.... not $1,500.
Been a couple years. No sign of problems yet.
I figured nothing from nothing leaves nothing, right?
Had a guy with the pan in a swamp cooler rusted out.
$450 for replacement cost plust the cost to install.
POR-15; fiberglass and paint. Claims a few years
of use later and no sign of problems.
My kids used to step onto the "dash" area of our ski
boat on the way to the bow to pull the anchor. They'd
sometimes step into the "glovebox" area where the
stereo resides. Cracked the plastic housing.
Stereo was about to fall out. POR-15 and fiberglass
and you'd have to look two, maybe three times to
recognize there was a problem. Kids been traversing
the area ever since. I conclude stronger than was, because
I have not had the problem recur (or maybe they learned).
My '91 Astro van was peeling paint. Typical problem.
Sealed with POR; covered and worked at restoring paint,
short of the thousands of dollars autobody shops insisted
needed be spent becuase the primer was bad.
Not to end on a bad note: But, I did use the POR stuff
on the body of my '69 truck. Worked poorly. Paint is
peeling; cracking and looking real bad. I conclude
a number of issues: Paint shot in winter with too much
precipitaiton; mixing of paint products; products not
curing thoroughly (I think this last was the greatest
problem.)
I have had POR spill and dry in places I really didn't
want it. The stuff is very, very hard.
In a thread recently the question was asked: Can you
sandblast POR off? An answer was: Yes, but with some
difficulty, or words to that effect (not an exact quote,
here.)
This last paragraph, I think, is testament to the
longevity of the material.
Tell me about your experiences. I know there is far
more to share.
Oh, and by the way, if I painted a surface with POR
and saw any amount of rust, I think I'd just paint it
again and keep on going. Far too easy. Far too cheap
to ignore.
What have you to add, if anything?
excitement.
problem.)
here.)
more to share.
to ignore.
Hi Guest!
